workinonit
Elite Member
+1
Maybe you saw it, but you didn't agree with it, so you discounted it.
And, it depends on what your definition is, of a "simple" stand alone it...
SR
That's what I ended up going with a portable Generac GP17500E & I didn't want to go this route because it's another engine that I will need to pm every yearProbably. But for us this isn't a theoretical discussion. Power outages of 3 or 4 days happen often in these mountains. So I thought to share some thoughts because we have a lot of knowledge dealing with power outages. The reason I prefer a stand alone generator is based on experience.
What I mean by "simple" is that the generator is simply a generator. No other function.
Things that make the Honda's local favorites are how quiet they are and how fuel efficient. They are very sophisticatd. It's remarkable how quiet they are. I can hear it enough to tell it is running, but can hold a normal conversaton while standing next to ours. Outside on the porch, it doesn't make enough noise to hear inside the house.
Downside to the Honda is that they cost twice to three times what the louder generators do. A neighbor has one from Home Depot that you can hear everywhere on his property and inside as well. It also uses several times the fuel that the Honda does.
The arguments in favor of the Tractor PTO don't work for us, because the tractors ares needed to deal with whatever caused the power outage in the first place.
rScotty
Whatever gives you the right voltage and cycles.
Higher engine RPM will have more engine flywheel inertia to resist a sudden load.Most likely the higher engine rpm will be more stable, but it “could” depend ....
Because of gearing TO the pto, the higher RPM will have more torque to the pto/generator to cover heavy loads.Higher engine RPM will have more engine flywheel inertia to resist a sudden load.
I don't have any noise issues as my standby is out by the shop which is about 350 feet from the house and being a well muffled diesel and I can only barely hear the turbocharger whine. Myself, I'd never have a tractor driven pto genny. I have no desire to one, tie up a tractor and 2, run any of my tractors for hours on end at rated pto rpm. Finally, I don't want the added inconvenience of hooking up and unhooking a pto generator every time the power fails. Much easier for me to let the standby assume the load and do an automatic transfer of current completely hands off. All the controls and transfer switchgear are inside the shop out of the weather. if I'm not home and the utility fails, my wife don't have to worry either. Peace of mind is worth everything to us.Probably. But for us this isn't a theoretical discussion. Power outages of 3 or 4 days happen often in these mountains. So I thought to share some thoughts because we have a lot of knowledge dealing with power outages. The reason I prefer a stand alone generator is based on experience.
rScotty
That hasn't been MY experience. The only tractors that lose rpm on hills while mowing, are the tractors that are under powered or don't have good low-end torque. OR you are in too high of a gear, for that slope.Tractor diesel governors are not like engine powered generators governors that control engine rpm to maintain a certain rpm and Hz cycles. Tractor diesel governors really only work at low or too high rpm. Ever mow sloped field? Rpm changes down and up hill. Can lower or increase throttle to maintain rpm but is not automatic or governored.
SR
This is just simply not true if the tractor is large enough for the load. And if diesels didn't control gens well, they wouldn't be so popular on standby gens. Here's the bottom line. There are a lot of you that for whatever reason don't like PTO generators. That's fine, but PTO gens work really well. In my opinion they are much better than standbys because I know my tractor will start, the standby you never know. Yes, it's not automatic but I really don't want it to be. I like to be there and know what's going on before I tie my gen to my houise load. It all boils down to the fact that it's an opinion and goodness knows, everyone has three of those.Tractor diesel governors are not like engine powered generators governors that control engine rpm to maintain a certain rpm and Hz cycles. Tractor diesel governors really only work at low or too high rpm. Ever mow sloped field? Rpm changes down and up hill. Can lower or increase throttle to maintain rpm but is not automatic or governored. You can maintain voltage and hertz pretty well and some loads like heaters and motors are tolerant to fluctuations. This does require some input from the operator. They do have a certain applications.
Stand alone generator generators can maintain clean power easily.
We have a 30+ year old Miller welder/generator gal/hr and 17 year old Yamaha 2400 watt inverter 1.75gal/8hr generator. Latter was run for 4 hours, refrigerator, freezer, lights, internet tv, wood stove fan and medical equipment last week. Our lifestyle and requirements make having back up power necessary.
There are many options and solutions.
Let’s add tractor water temp & oil pressure monitoring while we are at it.Seems like this discussion is ripe for someone to propose a frequency controlled governor retrofit.
Funny how the best gen manufacturers make diesel gensets and they are preferred by most buyers. Experience, I've owned one since 1998 and used it for lots of things. It's mounted on a trailer that I hook behind my tractor and my welder and a small air compressor will fit on. I've run it behind 2 different JD tractors and both ran it flawlessly. The tractors control it to within 2 to 3 volts. Maybe the ones you are aware of aren't sized properly or are attached to tractors that don't control loads very well. I was stating my opinion but what you wrote was just simply not the truth based on my many hours of experience.If pto generator works for you that’s great! Sized to a tractor and loads required. Worse is low hp tractors and small generators.
Diesel engine generator governors are different than what’s on tractors so your point is null.
Local sawmill uses 3phase diesel generator to power their mill. Owner was talking on looking for a replacement because of 15,000+ hours. 40Kw. Had another genset for a planer and resaw operation. I asked how about a pto generator? He had lots of tractors and existing fuel supply? He said we tried that, don’t work, can’t take the variable loads, burnt motors, ate fuel, it’s over there in the shed if you want it. Granted he was not your typical backup power user.
Pto generators have their place. Can get them at scrap prices at auctions around here. If they satisfy your need that’s great. I tend to now measure success in decades of use.
Sharing experiences helps us all. Your experience is valuable.
