PTO generator at max torque or max HP?
   / PTO generator at max torque or max HP? #11
And for anyone wanting to do their own math on the hp vs kw, 1hp = 746watts, 1kw =1000watts, 1000watts = 1.34hp. So 15hp would be ~11kw.
And that at 100% mechanical efficiency which is unattainable. There is always some level of parasitic power loss.
Thanks all for the good information. The generator has an analog voltmeter with a green zone for proper operating speed. In addition, I will have a plug-in digital voltmeter to set the engine speed to get 120v output. I have not yet put the generator into practical operation but did try it out to check voltages. The higher the rpm the higher the voltage. I knew but did not apply the fact that gearing means torque multiplying. Even though the engine might have the highest torque at 1600rpm, you can multiply that torque upward with gearing. Thus the 2200rpm at the engine geared down to the 540 output speed at the pto will give me the highest torque. I will also have convenient plug-in voltmeters in the house to monitor the generator output.
   / PTO generator at max torque or max HP? #14
I just bought a 15K watt generator which I will be putting on a 12K watt circuit. I will be attaching it to a Mitsubishi 180D three cylinder diesel tractor. The tractor has a three speed PTO. Running at the standard 540 setting, the engine will run at 2200rpm which is close to the max horsepower speed. If I run the PTO at the mid setting, then the engine will run at 1600rpm which is close to the max torque speed for this engine according to the owners manual. Which option should I choose for stable sustained operation?
Nepa, just out of curiosity, what did you end up buying for generator? Sounds a lot like my 15k Winco, which the manual states requires 29 PTO horsepower to run. Do you know how much output your Mitsubishi has in it's lowest (highest engine rpm) PTO gear?
   / PTO generator at max torque or max HP? #15
And that folks is why a stand alone generation system designed to spec is much more simpler to operate....
DL, while I agree with you that stand-alone systems are much simpler to operate, there are a few advantages of PTO generators that help offset the disadvantage of their complexity.
Just sharing from my own experience, but we used to own a Generac 11K propane stand-alone unit to power our property during outages. A couple seasons ago we sold it and replaced it with a 15K Winco PTO and it's been great for us. While we have some extenuating circumstances due to our relatively remote location, the main reason for our switch to a PTO generator was fuel type and long-term reliability.
After calculating the fuel consumption rate of the 11K propane Generac at ~3 gal./hr., I determined that our 500 lb. tank topped off with 400 gallons of propane could run the Generac for 5.5 days before exhausting the propane supply. While this seems like plenty of time for most people to have their line power restored, we often go without power for 2-3 days during an outage due to our remote location and low priority. During the infamous East Coast ice storm of 1998, we were without power for 16 days. Furthermore, our location prevents fuel trucks from being able to reach our house in anything but the best conditions.
While the fuel consumption rate remains comparable at ~1.5 gal./hr. with our Mahindra 4540 turning the Winco, refueling is a breeze with my 100 gal. pickup-mounted skid tank. Power is typically restored to the fuel stations along the main roads fairly quickly, so I theoretically never have to worry about running out of fuel.
I was also worried about the long-term reliability of the stand-alone unit. A small propane engine that sometimes has to start in below-zero temps and goes straight to operating full-throttle with zero warm-up period doesn't seem like a recipe for longevity to me. Admittedly, restoring power to our home in the middle of the night with the Winco is a much more complicated process. However, having the ability to warm up the tractor and generator before putting them into operation gives me the confidence I need to trust this setup long-term.
Without a doubt it all comes down to your specific needs and priorities. I can imagine that what works for me very likely seems like an over-complicated process to others. Just thought I'd share.
   / PTO generator at max torque or max HP? #16
Does this generator not have a frequency meter? That will be more accurate than voltage in determining required prime mover speed.
Here is a link to some educational material about generators.
   / PTO generator at max torque or max HP? #17
Be careful, the rpm dictates frequency. You need 60-62 hrz, not that volts don't matter, but, RPM ties directly to frequency.
Best,
ed
   / PTO generator at max torque or max HP? #18
Frequency and voltage are linear when discussing conventional PTO generators. An inexpensive Kit-O-Watt will verify that. They are a very useful tool.
   / PTO generator at max torque or max HP? #19
To the OP's first question it will all depend on the load on the generator.
If the household is up and active requiring hot water and cooking as well as lighting and heat the power demand will be much higher then,
in the middle of the night everyone has gone to bed and it's heat and maybe a water pump and a few night lights.
With light power demands you may be able to gear up and slow down the engine, with heavier loading most likely you will need the higher engine speed.
Most pto generators will have a voltage regulator adjustment, it can be brought up to speed to get 60 Hz and then the voltage out trimmed for the desired 120V.
As far as the stability of the pto generator that is total dependent on the responsiveness of your tractors governor and the engine characteristics.
   / PTO generator at max torque or max HP? #20
Don't forget that generator needs to run at 60 hertz. It should have a volt meter on it with a safe voltage band so that you can adjust the throttle to get the voltage and frequency correct. If it doesn't have a volt meter then you need to hang a VOM on it and verify the rpm it takes to maintain voltage and frequency.
If the PTO speed isn't the speed producing 60 hertz, your appliances will not only act funny but you may ruin them. My PTO generator has a gauge showing when the PTO is turning the speed to make 60 hertz.
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
20X30 ALL STEEL CARPORT (A55745)
20X30 ALL STEEL...
2011 CATERPILLAR 535C SKIDDER (A52707)
2011 CATERPILLAR...
UNUSED FUTURE XJ5T - 5T HYD THUMB CLAMP (A52706)
UNUSED FUTURE XJ5T...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
