GPM for a hay mower
/ GPM for a hay mower #1
Josephvalpatic
Massey Ferguson 135
What's the general GPM requirements for an old hay mower such as a John Deere 1209? The tractor I am looking to buy does 4.5. is that sufficient enough to run it at a lower speed such as 8-10MPH?
/ GPM for a hay mower #2
You might get a better answer if you tell us what tractor you are looking at. Also what part of the country and the type of hay will get you better info.
/ GPM for a hay mower #3
Are these mower conditioners not driven from a conventional pto shaft.
The only hydraulics are to raise and lower but not drive the implement.
If I am correct, then the hydraulic flow needed will be minimal.
Dave M040
/ GPM for a hay mower #4
I do not believe the mower will run anywhere near 8-10 mph. I know I would not want to be mowing that fast. The ride would jar your teeth out in most fields.
/ GPM for a hay mower #5
Mow hay at 8-10mph in a tractor? I’ve never seen a field clean enough to go that fast. I feel like I’m cruising when I get over 4.5, typically probably 3-4 MPH for cutting hay.
/ GPM for a hay mower #7
8 - 10 mph? Quickest way I've heard of to plug your mower up solid!!!
/ GPM for a hay mower #8
Just referenced my manual, it said it's capable of up to 9mph. She's a year old and high end of consumer-ish grade mowers. I knew it was single digits but couldn't remember max speed.
/ GPM for a hay mower #9
I'm going by the way my mower, a six foot sickle bar performs behind my 550 Oliver. If I'm cutting a healthy stand of Brohm-Alfalfa I can't go faster than second gear. If I'm using the Brush Cutter and cutting a thinner stand of same, I'm lucky to use third gear. This was a decent little unit in its day with 40hp. It still runs quite well and most of its horses still pull quite well at sixty some years!
/ GPM for a hay mower #10
I was just referencing a max speed for the mower according to the manufacture, I've never gotten anywhere close to that.
/ GPM for a hay mower #11
Only hyd on a mower conditioner like a 1209 should be to lift it, and you don't do that while running, PTO runs it. a 30 PTO HP utility with 4.5 GPM AND the correct PSI should pull it, power it and lift it.
8 to 10 MPH? Forget it. Maybe in perfect conditions when machine was new, but it's not new and conditions are never perfect. There is a reason discbines & disc mowers are the goto now.
I have an old sickle manual, also says 8-10MPH which is a joke. More like 1-2MPH and plug all the time.
I disc mow at 7-8 MPH, fields usually too rough to drive any faster at PTO RPM. No way would a sickle machine eat what I am cutting at that speed.
/ GPM for a hay mower #12
I agree that the sickle mower is old school and out of date but it's what I have and all I need. I only bale a couple or three hundred bales total per year otherwise I would be looking to upgrade. I don[t even use the bales for feed as I don't have livestock. I use them to cover cisterns and holding tanks in winter.
/ GPM for a hay mower #13
For sure, you can buy a serviceable sickle bar for a fraction of a junk disc mower. If you are only cutting a few acres you can afford to take it slow and save $$$.
/ GPM for a hay mower #14
JD 1209 is powered by pto shaft. Hyd's raises platform. IIRC 1250 psi is required to hydraulically raise platform
/ GPM for a hay mower #15
You guys can keep talking sickle mowers but this appears to be a troll post that worked pretty well.
/ GPM for a hay mower #16
I have a JD 12-20 MoCo parked in the barn as a backup. I'd never consider anything but a disc machine for cutting hay, any hay anywhere. I keep it just in case.
Never seen any hay mower that was powered hydraulically, all pto driven that I've seen.
/ GPM for a hay mower #17
A New Holland 499 center pivot is hydraulically driven hay mower.
Came out in 1983 and is still in production today, I believe.
Might be the most popular hay mower of all time. Theres a hydraulic pump on the tongue driven by the PTO.
/ GPM for a hay mower #18
There are several haybines and a few discbines that are hydraulically powered,
however none of those are powered by the tractors hydraulic system they all have there own PTO driven pumps.
Then most of those are also the hydra swing type that will trail behind the tractor going down the road,
then when you start mowing will swing out to either side of the tractor.
So you can pull into the field swing it out to your right side, do your head lands, turn around and do your back swath,
then start down one side, turn a 180 and hydra swing to the left side and mow right back up the same side, get to the end turn 180 swing the mower to the other side and repeat till done.
So they do usually require two tractor remotes one two for the swing cylinder and one single action or floating for the header lift.
/ GPM for a hay mower #19
My first hay rake was hydraulically powered Deere roll bar. It was a very nice rake. Had a front “trike” wheel. Ran off tractor remotes, but fluid got hot running it after a while.
Man those were the days.
