Just picked up a 336.. couple quick questions
/ Just picked up a 336.. couple quick questions #1
walnutman
Gold Member
Ben Wheeler, TX
Yanmar YT359C, John Deere 310SE
Runs good. Looks decent.
There is a large 2-1/2" or so finger wheel that has open and close on it just under the seat facing forward. Right now it's frozen so I'm spraying the threads, tapping lightly with a small hammer and trying to turn it every so often. What is it for?
Also the draft control for the 3pth lever is also frozen. Doing the same with that. Hopefully these things will break free eventually. I can't use heat due to seals and such I suppose.
/ Just picked up a 336.. couple quick questions #2
Congratulations, very nice tractor.
That finger wheel controls the the rate at which the 3pt hitch drops.
The other thing - the 3pt draft control lever - is probably frozen because nobody ever used it.
In fact, both of these adjustments are rarely used.
There is a lever at the 3ph that moves up and down. Bunch of flat linkages wrap around the yoke of the upper arms. Not sure what it does. I ordered all the manuals today
/ Just picked up a 336.. couple quick questions #4
That lever engages/disengages draft control to regulate the ground engagement dept for an implement attached to the 3pt hitch. It's sort of a hold-over from the days when tractors were used a lot for plowing. When plowing it keeps you from having to constantly have a hand on the 3pt lift & lightning reflexes. It's not useful for much of anything else. I don't think I've used that feature on any tractor in 30 or 40 years.
Except once when I left it engaged by accident.....
To see how draft control works, take a look at the top connection of the 3pt hitch on the back of the tractor. See how that top link connection it is actually a pivot and lever?
Well, when the plow contacts an obstruction like a rock underground it puts compressive force onto the top link. That lever is on a heavy spring, but it moves just enough to open a valve inside the rear end that instantly raises the 3pt lift arms an inch or so. If that doesn't clear the rock, it all happens again...very rapidly.
Draft control forces are only crudely adjustable. Most of the time you don't want draft control, so you disengage it with that lever that is frozen up.
Forgetting to disengage draft control when using a 3pt mounted backhoe used to be the cause of many farm-related accidents & deaths.
rScotty
/ Just picked up a 336.. couple quick questions #5
/ Just picked up a 336.. couple quick questions #6
I have a 336d. Decent little tractors.
/ Just picked up a 336.. couple quick questions #9
I have this marked from 2011 336D it may help?
  • 336D wiring diagram0001.pdf
/ Just picked up a 336.. couple quick questions #11
Tach and hour meter are mechanical.
I just got the manuals. The finger control... maybe you misunderstood... the valve in front... its a wheel. It's used simply to turn off the the. Draft control is not seized. The little lever on the tph valve is the drop speed control. It's seized on slow
Well that explains that lol. How does a mechanical hour meter work? Parts list shows a cable for the hour meter in the electrical section.
rScotty
Reading the manual, draft control maintains implement depth when traversing hills and swales. It also reduces depth when the ground gets harder to help maintain power. This lever is not frozen. Looks clean and in working order.
/ Just picked up a 336.. couple quick questions #15
On the fender wall, there are these decals for the draft control.
The draft control also works with a bottom plow on gradual slopes. Ideal for potato farming on sloped hills.
/ Just picked up a 336.. couple quick questions #16
rScotty had posted these in an older thread here. It's not often seeing good reference material like this.
/ Just picked up a 336.. couple quick questions #17
More from rScotty, see the attached
  • Yanmar YM276 YM336 Brochure_compressed.pdf
/ Just picked up a 336.. couple quick questions #18
Works like an old speedometer. You may not have the time but if a big interest this will show you how it works.
But how does engine rpm mechanically translate to time? At idle time would slow down. At full power time will speed up.
To answer my own question I just looked it up. It's only accurate at 540 pto rpm engine speed. At idle it will register less actual time. The only accurate ones are electric ones. Even with those if you accidentally leave the key on you record false hours.
/ Just picked up a 336.. couple quick questions #20
You got it!
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
UNUSED RAYTREE RMLL60 - 60" POWER RAKE LAND LEVEL (A62131)
UNUSED RAYTREE...
Unused SDL-4000 10,000lb. Two Post Auto Lift (A61568)
Unused SDL-4000...
2013 FORD F250 (A60460)
2013 FORD F250...
CATERPILLAR 140 AWD MOTORGRADER (A63276)
CATERPILLAR 140...
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
