Upgrading From the Dewalt 18V Platform
/ Upgrading From the Dewalt 18V Platform #1
lostcause
Maine
I didn't want to bury this in the recent "cordless tools vs." post, so I'm creating this separately. I'm assuming I'm not the only person still limping along with this ni-cad dinosaur platform, so maybe any others out there can either help with my questions or learn a few details along the way as I make a move to upgrade.
I've got a reasonable amount of these tools: 10-12 total, with 9 batteries: 6 xrp & 3 regular. Some of this stuff I paid retail price for, and some I got at ridiculous deals over the years both new & used. for example, i paid $18 for a 2-pack of xrp batteries still sealed in the clamshell. but i digress... i recently had two of my xrp batteries fail - won't charge on any of the several chargers i have. they're all getting pretty well aged, and some of the others don't seem to hold charge well, so i know i'm on borrowed time. around here everyone is buying the milwaukee fuel 18v stuff like there is no other alternative. my question is, do i cut bait and jump too, or do i stay with the Dewalt brand and move the 20v max platform, hopefully gradually.
I've tried to do research online, but I can't find any large definitive lists of what works and what does not work when using the 20v max batteries in the 18v tools. the dewalt faq has one partial list (I will link it here in a bit) but it only has 2 of the tools i have and the information was unclear. Because of this, i'm going to post all of my tools with a list of what works and does not work for everyone's benefit, and also pose any questions I have about why something does or does not work, and hopefully someone can provide an answer.
Here's the test platform:
Dewalt DCA1820 adapter and DCB207 1.3ah battery
and the tools:
DC011 radio/charger - untested so far
DC970 drill - seems to work fine with the test platform listed above. Dewalt states not to use premium batteries with this tool. assume that's the higher output batteries only?
DW908 light - seems to work fine
DCS370 band saw - adapter will not fit tool. I saw this note on the link below and assumed it was a battery / adapter clearance issue, but it is a design issue. the adapter has some lugs on the post that will not allow the tool electrical contacts to make contact with the battery contacts.
DC390 circular saw - seems to work fine, but will not quite cut full depth with the 1.3ah battery, however it appears that you can cut 1-1/2" framing lumber with batteries up to 5ah or maybe even larger? I have nothing that large to do a definitive test with at current time.
DC385 reciprocating saw (have 2) - seems to work fine
DCD970 hammer drill - seems to work fine
DW919 light - seems to work fine
DC825 1/4" impact driver - seems to work fine
DC410 cut-off tool - untested so far. tool stopped working previously - need to determine whether it is armature or brushes or other.
DW059H 1/2" impact - seems to work fine
I will post my results with each tool as I go.
here's the link to the Dewalt FAQ with more of what does and does not work:
/ Upgrading From the Dewalt 18V Platform #3
I have a bunch of Dewalt 18v stuff as well, I don't use it much any more. I'm not sure what to do with it. I have a ton of 18v Makita as well which gets used all the time for work, in my garage I have tons of Ryobi 18v and love every piece of it.
I'm thinking I'll probably end up giving hte Dewalt stuff away.
If it helps, I bought some knock off batteries off Amazon or ebay and have no complaints with them and they were cheap.
I write the date on every tool and battery when I buy them just to keep track of them and to slow down theft.
If the tools work for you look into the knock off batteries.
ETA: I understand you can buy adapters to run any battery platform in any tool, maybe a Ryobi battery to the dewalt tools? Batteries are usually 99 a pair for 4 ah batteries
/ Upgrading From the Dewalt 18V Platform #4
Dewalt 18 volt batteries are top post where the 20 volt batteries are flat top. Nothing is directly interchangeable. They make adapters. They’re kinda clunky but that might be an acceptable compromise for light use.
/ Upgrading From the Dewalt 18V Platform #5
I would suggest looking for a reputable online source of raw NiCAD and NiMH replacement cells. Used to be a number selling the cells pre wired to open your old battery to swap.
/ Upgrading From the Dewalt 18V Platform #6
I dont have anything against Dewalt. I started in Milwaukee about 8 years ago and still have every battery I started with and they work fine. No tool failures Yet. Main tools have been bullet proof for my needs. I usually wait for a deal at Hone Depot then get what I need. Batteries on this platform are expensive but very good. So look for deals that give you ”free” ones.
so, i've tested most and came up with the surprise when i encountered a deliberate design feature prohibiting me from connecting the adapter to the band saw. I've googled and can't find an answer, so does anyone have any idea why this might be? the nominal battery voltage for these batteries is 18v, so what could the difference be that they don't want you to use the adapter, and also, to aftermarket adapters all have this limitation too?
my failed batteries are stamped 2009 & 2010, so I've got zero complaints on the quality and longevity. i have some functioning 2008 & 2009 still, and my newest is 2014, so they all have done fine by me.
/ Upgrading From the Dewalt 18V Platform #9
so, i've tested most and came up with the surprise when i encountered a deliberate design feather prohibiting me from connecting the adapter to the band saw. I've googled and can't find an answer, so does anyone have any idea why this might be? the nominal battery voltage for these batteries is 18v, so what could the difference be that they don't want you to use the adapter, and also, to aftermarket adapters all have this limitation too?
I've used the adapter on my drill, recip saw, circular saw, and impact driver. Works great.
/ Upgrading From the Dewalt 18V Platform #10
I haven't looked at all but know that my M28 Milwaukees can't last forever. The problem is that none of the newer tools are built half so well.
Maybe this is common, but do any of the companies offer a Lithium battery pack to directly replace the older Ni battery pack?
/ Upgrading From the Dewalt 18V Platform #11
I had 18volt dewalt before. Now have the rigid tools. Going on 5 years now and no complaints. Price was main influence. Cordless multi tool and the drill/drivers are most frequently used of the bunch.
if I was buying today, I would look at other brands that offer chainsaws/weed eaters too.
/ Upgrading From the Dewalt 18V Platform #12
If it was me, I would notch the tool or adapter with a Dremel or open the case to modify it to accept the adapter. My guess it is because of a limit that they don't want that saw running on 20V for a long period of time.
/ Upgrading From the Dewalt 18V Platform #13
DeWalt sells an expensive adapter to use current 20v lithium on classic 18v. The adapter slowly drains the battery if one leaves it connected.
/ Upgrading From the Dewalt 18V Platform #14
In theory, the adapter should allow any 20V battery on any 18V tool, I don't know why there would be restrictions.
I'm in the same boat. I bought 4 non-Dewalt batteries from Amazon, 2 Li-Ion and 2 NiMh. So far so good, but I have doubts if they'll last 20 years like the Dewalt NiCds did.
Dave
/ Upgrading From the Dewalt 18V Platform #15
I use the Dewalt 20V Max tools. I have one 18V that when it dies I will replace it with the 20V model. My newest is the 4 1/2" circular saw. My wife loves that one for cutting plywood.
/ Upgrading From the Dewalt 18V Platform #16
The 18 and 20 volt batteries are really the same voltage but if somehow you did end up burning up an obsolete tool nothing was lost. And I don’t see how the 18 volt tool was intentionally designed to not work with the adapter since the flat top batteries and the adapter was designed after the 18 volt tools were built.
/ Upgrading From the Dewalt 18V Platform #17
I know that the old NiCad Ryobi tools share the same platform as the new Lithium battery's and the tools work great with them. In fact they perform better than original. I know they aren't the contractors tool of choice, but for most homeowners they are fine.
However the 1/2" impact gun that Milwaukee sells has converted me. That tool is the ultimate. I love that thing. Since I bought it I have slowly transitioned over.
/ Upgrading From the Dewalt 18V Platform #18
For the "won't work" list, add 18V Vacuum because of physical fit problem.
I bought an adaptor and kept a couple 18V Dewalt tools, but replaced most of them with their 20V Max series. As 4570Man said, there's no real difference in voltage between 18 and 20V. A couple of us from our company were invited to a preview of the new platform before it was unveiled and the engineers said DeWalt wanted to be able to differentiate between the NiCad and LIon platforms (plus it occurred to them it wouldn't be bad marketing to make them sound 2V more powerful).
There's a big difference between the 18V and 20V tools with regard to cold weather performance, Batteries not discharging when not in use and run time - especially with the brushless tools.
I do have an M18 Milwaukee drill and light that were a freebie and like them both. The drill seems to have a slightly better speed regulation than my Dewalts, but torque seems the same. We did a head-to head test taking lugnuts off a Gradall and the Milwaukee tied with my DeWalt 899 impact.
/ Upgrading From the Dewalt 18V Platform #19
Just start with some 20V batteries, and the adapter maybe?
I bought a knockoff version of this battery adapter for like twelve bucks. Works GREAT! Some tools dont' need updating, like the circular saw, sawzall, etc. But for the rest, the new brushless motor stuff is incredible. Half the weight and more power and run time.
/ Upgrading From the Dewalt 18V Platform #20
Many many years ago I purchased some
black & decker tools. skil saw had 1/2 inch
slop in the blade ruined a 3/4X4X8 sheet of
plywood returned it. Had a black & decker drill
1/2 inch total crap gears you could push over
with your thumb went in trash heard that black
& decker purchased dewalt so never purchased
anything by dewalt. Roybi have had drills from
them over 20 years still working and have a
Milwaukee tool bag full of tools over 10 years ago
still working fine.
I had one battery that would not charge but I pulled
the plug and plug jin and out 4 or 5 times now battery
works fine.
willy
48x4 Mini Skid Trencher (A63118)
48x4 Mini Skid...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
CASE IH 215 PUMA TRACTOR (A62130)
CASE IH 215 PUMA...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
INOP/NON-RUNNING 2005 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDL85HN88678 (A61165)
INOP/NON-RUNNING...
