Kx121-3 hydraulic swing problem
/ Kx121-3 hydraulic swing problem #1
Tyemrick
Kx121-3
Been having two issues with my kx121-3 excavator. Hoping you guys might be able to lead me in the right direction. My machine has been sitting for a month and it’s been really cold 18 degrees. I started the machine up and let it warm up for 5 min before moving it around. All the boom functions work fine but when I go to swing, it starts then keeps swinging. I loose all swing function left or right. Then either I shut it off or wait a few seconds then it will swing fine. I parked it on the job and didn’t want to start digging with it because I might hit something when I go to swing.
The other problem is when I trailer it and go to start it for the first time or park it on an incline and turn it off. I will restart it and have no hydraulic functions other than if I move the joy stick to let the boom drop or bucket curl it will slowly bleed pressure off and lower slowly. I either throw the safety lever up and down a few times or start the machine at high rpm then everything works fine again. Any thoughts?
/ Kx121-3 hydraulic swing problem #2
I’m assuming this is a hydraulic over hydraulic control setup. It sounds like the controller lines is leaking.
/ Kx121-3 hydraulic swing problem #3
What's the hyd fluid level?
I will check for leaks tomorrow on the controller lines from to joystick
PALLET OF GANDY APPLICATORS (A64278)
PALLET OF GANDY...
2008 JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
2008 JOHN DEERE...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
2004 Caterpillar 315C Hydraulic Excavator (A64194)
2004 Caterpillar...
