Kx121-3 hydraulic swing problem
   / Kx121-3 hydraulic swing problem #1
Tyemrick
Kx121-3
Been having two issues with my kx121-3 excavator. Hoping you guys might be able to lead me in the right direction. My machine has been sitting for a month and it’s been really cold 18 degrees. I started the machine up and let it warm up for 5 min before moving it around. All the boom functions work fine but when I go to swing, it starts then keeps swinging. I loose all swing function left or right. Then either I shut it off or wait a few seconds then it will swing fine. I parked it on the job and didn’t want to start digging with it because I might hit something when I go to swing.
The other problem is when I trailer it and go to start it for the first time or park it on an incline and turn it off. I will restart it and have no hydraulic functions other than if I move the joy stick to let the boom drop or bucket curl it will slowly bleed pressure off and lower slowly. I either throw the safety lever up and down a few times or start the machine at high rpm then everything works fine again. Any thoughts?
   / Kx121-3 hydraulic swing problem #2
I’m assuming this is a hydraulic over hydraulic control setup. It sounds like the controller lines is leaking.
   / Kx121-3 hydraulic swing problem #3
What's the hyd fluid level?
I will check for leaks tomorrow on the controller lines from to joystick
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
Hustler Raptor SD 54 in. Lawn Mower (A53117)
Hustler Raptor SD...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
