Kx121-3 hydraulic swing problem
   / Kx121-3 hydraulic swing problem #1
Tyemrick
Kx121-3
Been having two issues with my kx121-3 excavator. Hoping you guys might be able to lead me in the right direction. My machine has been sitting for a month and it’s been really cold 18 degrees. I started the machine up and let it warm up for 5 min before moving it around. All the boom functions work fine but when I go to swing, it starts then keeps swinging. I loose all swing function left or right. Then either I shut it off or wait a few seconds then it will swing fine. I parked it on the job and didn’t want to start digging with it because I might hit something when I go to swing.
The other problem is when I trailer it and go to start it for the first time or park it on an incline and turn it off. I will restart it and have no hydraulic functions other than if I move the joy stick to let the boom drop or bucket curl it will slowly bleed pressure off and lower slowly. I either throw the safety lever up and down a few times or start the machine at high rpm then everything works fine again. Any thoughts?
   / Kx121-3 hydraulic swing problem #2
I’m assuming this is a hydraulic over hydraulic control setup. It sounds like the controller lines is leaking.
   / Kx121-3 hydraulic swing problem #3
What's the hyd fluid level?
I will check for leaks tomorrow on the controller lines from to joystick
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
