dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,586
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
See if the relief valve is adjustable as GRS said. That would be the first thing to try. That crushed hose could well be an issue too and you may want to consider replacing that in any case. I know it is a pain but it would be good to see the flow and pressure at a couple points in the system. Not sure where you have it now, but I would want to see it right after the pump, before the relief valve, as well as right after the relief.
You sure the pump is getting good fluid supply too? Fluid level good, tank pickup not clogged?
