Stability question-wheel spacers
/ Stability question-wheel spacers #1
oldline1
Huntsville, AR
John Deere 1025R
I have a JD 1025R and I maintain a very hilly 20 acres. It can get scary at times on the hills as it seems top heavy. I was checking out the Bora wheel spacers and wondering if that would help me.
Anyone used these spacers? Do they work as advertised? Do they cause undue wear on the axles or tranny? Would you recommend just rear spacers or both front & rear? I sure don't want to cause any premature wear or maintenance on my 1025R.
Thanks,
Roger
/ Stability question-wheel spacers #2
Never heard of premature wear using spacers in over 12 years and I keep my ears open. I have a JD 3720 with 4" on each rear side and with hills it nicer. Fluid in the rears is a must and wheel weights help a lot. Caution is always a must on hillsides even with spacers and weights. If you have a mid mount mower, spacers may not work because of mower protusions.
/ Stability question-wheel spacers #3
Check your Owners Manual. They should tell if spacers are OK. My OM does not speak about spacers. It's because my rims are agriculture rims and have adjustments for wider/narrower. I have my rear rims set out at their widest setting. My front rims are set at the neutral setting. I have 775 pounds of Rim Guard in each rear wheel. The spacing & rim guard help a lot.
Side hilling can be very dangerous. Front or rear tire falls into a shallow hole and you could be up side down in a flash.
My OM does say - no double wheels.
/ Stability question-wheel spacers #4
I put 600 hours on an L3400 with 6" rear spacers from Bora. The rears were loaded with Rimguard as well. I mowed predominantly sidehills. No issues with the axles.
/ Stability question-wheel spacers #5
Front spacers are of limited usefulness due to the pivot on the front axle.
When I bought my current tractor I had it set up with slightly smaller wheels and tires from a similar model (to lower the CG), wheel spacers and Rimguard. It is very stable on side hills compared to the last tractor which was smaller and narrower. Since I did not try it in stock configuration I don't know how much each of those helped.
/ Stability question-wheel spacers #6
I put BROTEC wheel spacer on back of my MF GC1715 and the extra 6 inches of width made all the difference in the world for stability.... If there is ever a wear problem with axle bearings I will deal with it when it happens.....
This ought to convince you about spacers...
/ Stability question-wheel spacers #7
Added 2” rear wheel spacers and liquid ballast to our Kubota B26 to help stabilize 3pt mowing on our hilly property. Made a big difference. Helps also with loader work.
/ Stability question-wheel spacers #8
Thanks,
Roger
I put 2" spacers on my BX2370. Before when I mowed my side hills with the belly mower I had to do it on a diagonal and a few times I felt a wheel lift. Now I can go straight across and it doesn't feel tippy at all. I have also bought some dumbbell weights to use as wheal weights, used weights are around $1 / pound. My BX needs 10# plates to fit in the rims. All I need to do is buy a drill press to do the job $$$.
3
Thanks for the help with this. Yes, my JD has a mower deck so I'll just get with Bora and see how thick they recommend.
/ Stability question-wheel spacers #10
Because of my 60" deck width and how wide my tires are 2" is as wide as I could go. I have about 1" clearance, I don't think I would want to go any wider.
I also have a 60" mower deck so that's good info. Many thanks to you and the others for the help.
/ Stability question-wheel spacers #12
My older Ford 1750 had slightly offset front rims which I flipped outwards.
The rear rims were a two-part rim. So, I flipped all the pieces so it was as far out as it would go.
It widened the tractor a bit, and feels more comfortable on the hill.
The front axle has a free pivot, so all the stability comes from the rear wheels. For hauling stuff with the bucket, I've added stops for the front axle pivot. It helps a lot. But, it impacts traction and is inconvenient when not hauling or suspending heavy loads with the bucket.
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
(INOP) KUBOTA ZG327 ZERO TURN LAWN MOWER (A62130)
(INOP) KUBOTA...
JOHN DEERE 3025E TRACTOR (A62130)
JOHN DEERE 3025E...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
