Dk5310se ballast question
/ Dk5310se ballast question #1
Jturning
KiOTI DK5310SE cab hst
I have a DK5310 on the way, I am building a ballast box and wonder how much weight I should have? I read the manual and it states to just have ballast, with no mention of how much. I am having the rear tires loaded with rimguard about 900lbs but wonder how much I should have out the back? Thanks
/ Dk5310se ballast question #2
It really depends on how much weight you're going to be working with up front, I see most guys just hook up to a piece of equipment such as scraper blade etc. and use it for ballast. I think if I were going to build a ballast box, I would probably shoot for something no less then 500 lbs.
I have a grapple on order, but it will not show up until spring. I have a sawmill and plan on using the full capacity of the loader.
/ Dk5310se ballast question #4
I ordered a 4 in 1 bucket and it's 10 - 12 weeks out also.
/ Dk5310se ballast question #5
i have a dk45 cab with loaded rear tires. my ballast box holds 1,000# of concrete. no issues what so ever.
Thanks, I was thinking 1000 pounds would be a good target.
/ Dk5310se ballast question #7
I saw/heard a suggestion recently on I think the "Good Works Tractor" channel (YouTube) where he suggested looking at the manual for a comparable Deere or Kubota model to get an idea of ballast.
I just wish I could get a good quality non freezing liquid ballast down here in southern California.
Dave
/ Dk5310se ballast question #8
I have the DK5810 with water in the rear tyres, ballast box about 600kg, often picking up 1000kg bulker food bags...... very carefully.
/ Dk5310se ballast question #10
I use 1100 lbs plus have filled rears.
/ Dk5310se ballast question #11
Dave
My tire guy gets methanol in 55 gallon drums,
it is mixed with water, similar to engine antifreeze, more methanol, lower freeze point.
Pick your lowest temperature, and mix.
I would imagine that the methanol is available, I think it is the same stuff some race cars burn.
Here is a pic of the tires I had filled.
/ Dk5310se ballast question #12
My tractor recommends about 1,000-1,200 lbs. And it's only a CK2510. A rear implement is not sufficient IMO; they don't weigh enough. Also IMO loaded tires do NOTHING as counter weight, ie reducing strain on the front axle. They do help to keep the tires planted but the rear axle is the pivot point for the lever that the tractor becomes when lifting weight i the FEL.
/ Dk5310se ballast question #13
Some tractors simply do not care about using the rear axle as a pivot point,,Spring9.jpg
/ Dk5310se ballast question #14
Specifications DK5310 - KL5520 Loader​
Maximum Lift Height to Pivot Pin107.7 in. (2,735 mm)
Clearance w/ Bucket Level96.3 in. (2,446 mm)
Clearance w/ Bucket Dumped78.8 in. (2,001 mm)
Reach at Maximum Height (45º)22.7 in. (576 mm)
Maximum Dump Angle46º
Reach w/ Bucket on Ground71.1 in. (1806 mm)
Maximum Rollback Angle41º
Digging Depth Below Grade8.6 in. (218 mm)
Overall Height in Carry Position54 in. (1371 mm)
Bucket Depth (Inner Shell)18.5 in. (470 mm)
Bucket Height22 in. (560 mm)
Bucket Length (Pivot Pin)26 in. (660 mm)
Lift Capacity to Full Height at Pivot Pins2,474 lbs. (1,122 kg)
Breakout Force at Pivot Pins3,895 lbs. (1,767 kg)
Bucket Rollback Force at Ground Line3,148 lbs. (1,428 kg)
Relief Valve Setting (Loader Control Valve)2,774 psi (195 kg/cm²)
Rated Flow (Tractor System)9.62 gpm (36.4 L/min)
Bucket Size(s) Available66" QA / 72" QA
Bucket Capacity (Heaped)66 in.: 14.5 cu. ft. / 72 in.: 16.0 cu. ft.
Approximate Weight (With Bucket)66 in.: 1,361 lbs. (617 kg) / 72 in.: 1,389 lbs. (630 kg)
/ Dk5310se ballast question #15
Some tractors simply do not care about using the rear axle as a pivot point,,View attachment 728042
I do not think that there is a tractor that will not benefit from the addition of a rear ballast. Several times I have witnessed tractors running without rear ballast but that does mean the wear and tear of a heavy load on the front axle could be reduced with the addition of the rear ballast. Also the addition of rear ballast on the tractor in your picture would reduce the need for wheel spinning and the use of the dif lock or brakes to walk back out of the hole that you were digging.
If you watch this video
you will see Mike pick up a cube of block and then without much warning the rear tires start to lift. On a hillside or working around a burn pit this could have be a serious problem. The lifting of the rear tires on a 2 wheel drive or a 4x4 in 2 wheel drive would mean there is no control of the tractor.
Is it a big deal? No most of the time it is no big deal but the chance of a disaster plus the reduction of wear on the front end by simply hanging a box blade or ballast box on the rear seam like a small price to pay for a safe day on the farm.
/ Dk5310se ballast question #16
Your name implies you might be an engineer, or at least more than competent with CAD systems. So you understand levers and leverage. So when you lift that bucket of dirt all that additional weight on the front axle is actually more than the weight of the dirt in the bucket. Because the bucket being out in front of the axle is creating a lever with the pivot point being the front ... wait for it; AXLE! This is why a big load in the FEL can lift the rear tires. Which is why some people load the tires, keeping the rear planted. But still all that stress is concentrated on the front axle.
But you knew that.
You just wanted to post a picture of your tractor doing some amazing digging. It is impressive. Sincerely. My tractor cannot do that unless my 1200 lb BH is on the rear.
/ Dk5310se ballast question #17
Ballasted rear tyres primarily help with traction by (hopefully) keeping the rear wheels on the ground.
A counterweight will be what reduces the load on the front axle components and makes steering a bit easier on a non-PAS machine.
Our little old Ford 3000 has liquid ballasted rears, but when I'm not using another implement on the back I carry a concrete counterweight to makes the steering lighter. It's about 2/3 of a 205 litre oil drum. I first thought it weighed around 500kg but since realised it's a good deal heavier than that.
Either way it's certainly worth having on there.
/ Dk5310se ballast question #18
On my 30 hp tractor with similar tractor weight and lifting capabilities I have a ~1200 lb ballast. I would not want to go much less that that. 1000+ lbs. seems like a good bet. I have lighter implements that I can use when I am not needing the big boy. It's scary using a FEL without some sort of ballast.
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A65563)
2021 Ford...
INSPECTION (A65583)
INSPECTION (A65583)
