Rounded off drain plug
/ Rounded off drain plug #2,061
Did my ears deceive me or was that Rain Man Ray. in Florida? He's become one of my favorite YouTube mechanics lately.
The YouTuber at South Main Auto Repair LLC is probably my favorite for taking out rusted bolts. He's somewhere up north where fighting rust damage is a big part of his job.
/ Rounded off drain plug #2,062
LOL. Yes, I've seen it. Never opened it I don't think. I'm always amazed at the topics that should have this kind of interest and don't vs the ones that have this level of intrigue and shouldn't.
There's another thread out there with a fellow that says he was napping is his hammock, I think while drinking beer, and he says he saw Bigfoot. It seemed to go on far longer than you would think.
/ Rounded off drain plug #2,063
Indeed, Rainman Ray in Florida. Always a good thing to watch.
/ Rounded off drain plug #2,066
OK, did the plug ever get removed? I wanted to know the solution, but just can't do it. I read 29 pages and still have another 180 to go. Or so. Now on page 207. How was it removed? If it ever was.
/ Rounded off drain plug #2,067
It was removed but can't recall how. I think a friend helped him.
/ Rounded off drain plug #2,068
Yes. Post # 1891...https://www.tractorbynet.com/forums/threads/rounded-off-drain-plug.393632/page-38
Plug out.
End of an era.
Go home folks.
Although you would have to start there and read further to see how he did it.
As for welding a nut on; I believe there were enough leaking fluids that he was concerned about setting the tractor on fire. While it would eliminate the need to change the fluids, that was deemed to be bit drastic.
/ Rounded off drain plug #2,069
Easy out: Rounded off drain plug
/ Rounded off drain plug #2,070
Grind a slot in it , use a big standard screw driver with 6 or 8 sided shank then use pipe wrench or vice grips has saved me on occasion, good luck
/ Rounded off drain plug #2,073
LOL,
That’s funny as h—- , I didn’t even notice this was first posted in 2018,Dan
/ Rounded off drain plug #2,074
Once blowhards get started they never quit.
/ Rounded off drain plug #2,075
I think you have a size problem.
I'm only on page 21 as of this post.
I like big pages.
/ Rounded off drain plug #2,076
A small pipe wrench with a pipe would have done it. Anyone ever figure out what those pallets in the field were for?
/ Rounded off drain plug #2,077
I like big pages
YTers aren't always on the same page but one thing we can all agree on "size matters".😉
/ Rounded off drain plug #2,078
Because of the configuration of the oil pan plug, a small pipe wrench wouldn't do it. Those aren't typical plugs but rather have a stubby "nut" section to grip on and with a large washer-like portion behind it that made gripping difficult. There was also a crossmember in the way and the owner seemed unable to remove that for better access. The owner was capable in many things but not experienced in the trauma of a buggered plug removal and didn't want to call in pro from a dealer. So things took longer. He finally removed it with help from his friend.
The pallet thing boiled down to two explanations for the pallets in the field. They were either part of an alien pre-landing strike force or maybe just someone's burn pile. Guys were fairly evenly divided. :)
/ Rounded off drain plug #2,079
A small pipe wrench with a pipe would have done it. ------------------
I don't understand why so many people post without reading the first page of a thread.
First post:
Tenth post:
And from the picture Kando posted it was a square head pipe plug:
/ Rounded off drain plug #2,080
And since I set 50 posts per page in "Settings" the thread is 42 pages on my computer:
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63118)
Neckover GL24-2-7K...
2019 FREIGHTLINER CASCADIA 125  EVOLUTION SLEEPER TRUCK TRACTOR (A59909)
2019 FREIGHTLINER...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
KUBOTA BUSH-HOG GEAR BOX (A62130)
KUBOTA BUSH-HOG...
