JD 310SG backhoe
/ JD 310SG backhoe #1
Redfender
John deer 310sg backhoe
JD310sg backhoe : park brake works fine but warning light and buzzer will not shut off
/ JD 310SG backhoe
Is there a way to disable the warning light and buzzer
/ JD 310SG backhoe #3
You should be able to unplug the sensor. That should shut off the light and buzzer.
/ JD 310SG backhoe #4
There might be a micro-switch on the linkage that is engaged. They are small and take a tine movement to engage and even less dirt and grime to make them stick. You might look closely at the linkage to see if that is something like that. It may be about 1/3 the size of a box of matches. If you find it, get a spray can of electrical cleaner with the little red stem. Blast it a few time from all directions. Then use a "gentle" air blasting to clean the solvent out. Make a couple applications and see if it clears up. If not, you might try to see if the switch is disengaging with a multi-meter by checking for conductance during the switch operation. BA
2025 Electric Cart (A61569)
2025 Electric Cart...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
1994 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61567)
1994 Gehl DL11-55...
2022 John Deere 520M Loader (A63116)
2022 John Deere...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2023 Globe Trailer...
