My Industrial Cabin Build
   / My Industrial Cabin Build #2,881
Sticking a Ventrac ain't easy, I would say that you actually got it tangled, not stuck.
as you drive along the small trees, you might be able to do in and out "S" turns, a bit in and out of the tree centerline to get between the trees too.
   / My Industrial Cabin Build #2,882
When mowing around trees I usually go to the left and then to the right of the next tree. It's a lot less turning. When I come back I do the opposite sides of the trees.
   / My Industrial Cabin Build #2,883
Do the Ventrac Slalom! :ROFLMAO:
The slalom sounds like the most efficient way.
   / My Industrial Cabin Build #2,885
Once an articulated tractor gets tight up against an obstacle, that articulated steering has it's own kind of issues.
   / My Industrial Cabin Build #2,887
When I built my house I rented a telehandler for the early stage work. The framers and roofers used it and then I used it for installing windows with the work platform it came with. It had selectable 3 steering modes. 1. Basic front wheels steer only 2. All wheel steering where the back wheels turned opposite of the front ones for tighter tuns and the real gem #3. Crab steering. You had to have wheels straight ahead to change modes, but you could get right up next to a wall if you wanted to, pop it into crab steering and both front and rear wheels would turn the same way so you could get away from a wall that was only a few inches next to you. That was a lifesaver in a few situations. Being that it was all hydraulic control/drive/steer, it was fairly easy to implement vs anything mechanical.
Just thought it was interesting...
   / My Industrial Cabin Build #2,888
The Toolcat has manual crab steering, very handy:
   / My Industrial Cabin Build #2,889
Nice pics of the crab capability of the Toolcat - my question is about the fence. That's a fine looking fence with painted metal rails thru the posts, and round tops.
Is this fence/post/rail something that was fabbed by you or purchased components? Also I see the end's/corner are welded flanged then lagged?
Looks to be about 5' high, 7' posts? Length of each run of metal 20'? Did you paint? How was the assembly done/connecting the rails - welding or sleeves? Rough cost Per Linear Ft?
Looking to do about 700' here next year and looking at options. Thanks in advance, and don't want to hijack Woodchuck' house build thread - if you prefer PM me.
Carl
   / My Industrial Cabin Build #2,890
Purchased in 2011. Priefert’s Ponderosa Fence: Priefert Fence | Fencing
No welding:
Ten years ago we had to pay a contractor $10 a foot installed. Expensive but worth it for the quality and safety for horses. The pictures above were taken 8 years after installation and it still looks new.
Went ahead and answered here, thought He and others would be interested.
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2014 Jeep Cherokee Latitude SUV (A53424)
2014 Jeep Cherokee...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
INOP/NON-RUNNING 2012 International WorkStar 7400 Vacuum Truck, VIN # 1HTWCAZN1CJ609461 (A54865)
INOP/NON-RUNNING...
