Grading--what am I doing to cause this?
   / Grading--what am I doing to cause this? #111
I guess being able to angle like that is a blade's advantage over a box blade. I can just tilt my box front to back and side to side of course.
I can angle my box blade using the crab steer mode of 4 wheel steering:
Notice the dirt windrow ^^^^
   / Grading--what am I doing to cause this? #112
Xfax, I picked up a load of fence posts Thursday and the only way they got them on my little trailer was with a loader that bent in the middle like that. I told the girl that she could have never done that with a tractor because there was a huge tank right behind her and she didn't adjust for it like you'd have to do normally.
   / Grading--what am I doing to cause this? #113
Have a 12 foot long grader blade 8 foot wide home made tilts in every direction used a mobile home axle and 400 # of weight it solved my washboard problem. Good luck
That is a nice rig. You should start a thread with more build details
   / Grading--what am I doing to cause this? #114
Land plane all the way. Mid range, let the dust fly. Worth every penny in less frustration and job well done.
Have a 12 foot long grader blade 8 foot wide home made tilts in every direction used a mobile home axle and 400 # of weight it solved my washboard problem. Good luck 😃
That's pretty cool, it's a mini-maintainer.
   / Grading--what am I doing to cause this? #119
Strange beasts, the box blade is in the front?
The front is Skid Steer Quick Attach (SSQA) and the 3 point box blade is on a SSQA to 3 point adapter:
What's relation to the Compact Telehandler?
Totally different machines, but I also can use the box blade on the front of it with the same SSQA to 3 point adapter:
   / Grading--what am I doing to cause this? #120
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2018 John Deere Z997R (A53317)
2018 John Deere...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
