Leveling ground for tractor shed
/ Leveling ground for tractor shed #21
looks good!! ... too bad i didn't see this post before I've work as a surveyor in construction before and I uses laser transit, then make littles piles on grade at intervals and paint the top once on grade, then fill in between using a rake .... a string works as well as you did but I find it takes longer and ya pure stone don't compact so you will always have that issue of the stone running away on ya over time ... I would suggest 0-2 inch (B2) material next time this thing harden like concrete ...
/ Leveling ground for tractor shed #22
Your tractor looks good inside your new building!!! Now the challenge is to NOT fill it up. :)
/ Leveling ground for tractor shed #23
Dang, looks great. I need that same exact shed to store my firewood totes and trailers. What was the installed price?
All in was $5500, plus the couple hundred I spent on gravel base material. 24x20, 8' walls and I upgraded to 12 gauge steel for the framing.
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
18' DOUBLE AXLE HAY WAGON (A62130)
18' DOUBLE AXLE...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
UNUSED TERRA FORCE 5' HYD WOOD GRAPPLE (A62130)
UNUSED TERRA FORCE...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
