Advice Please On Removing JD Quick Attach Pin
/ Advice Please On Removing JD Quick Attach Pin #21
I think the hole saw idea works. I've built a couple of JD QA implements and I just cut the hole for the pin with a hole saw and then welded it on the backside. Not much work. Although you can buy the pins, it's a common size and I just used standard pins. If I remember correctly, it's the top pin on a Cat 3 hitch. (Just my memory, better check to be sure.)
Victory!
Pin is tight and fits good enough for now. We'll mount the unit on the tractor for final fit and welding.
In the end I used the drill a ton of little holes around the perimeter of the pin then cut out the bulk of the pin.
Turns out the weld went halfway through the thickness of the plate, so grinding was not a good option.
The hole saw was a good idea, but I went with what I had on hand!
Once the center bulk of the pin was gone it was a matter of grinding and filing the remaining metal to true up and size the hole.
Thank you to all for the great ideas.
Back/weld side.
Pin. You can see how deep the weld will go.
Tractor side.
Decent fit.
/ Advice Please On Removing JD Quick Attach Pin #23
Be sure to clean up every bit of the rust from that pin. Nice shiny bright metal is what you need for welding.
Yup, I leave the important welding to my friend down the street who is a professional welder!
/ Advice Please On Removing JD Quick Attach Pin #25
Success! Many ways to do anything. Working with what you got to get the job done important.
/ Advice Please On Removing JD Quick Attach Pin #26
Good for you, it would not have been as good, I would have cut the pin off flush with a cut off wheel, and sized the new one, and welded from the front. Bet what you did took a minute.
It did take a while and broke one drill bit.
I have not looked so I am not sure if there is room to weld the pin on the loader side.
/ Advice Please On Removing JD Quick Attach Pin #28
Oh no, you did it right, and displayed patients I was not blessed with...........
Have a good one,
ed
/ Advice Please On Removing JD Quick Attach Pin #29
Hi all,
On the hay spear frame I have I need to replace one of the lower quick attach pins.
It is welded into a hole on the hay spear frame and the back side is accessible.
I don't have a torch available and it would probably make a mess anyways.
Grinding seems to be the best option but what to use?
I'm thinking about some kind of pointy grinding stone maybe to cut the weld?
As you can see in the picture with the arrow, the weld is pretty much flush with the plate.
Before I start cutting away at it I figured you guys may have some good suggestions.
Thanks.
Was able to get replacement pins at a reasonable cost.
/ Advice Please On Removing JD Quick Attach Pin #30
One approach might be to saw off the old pin as close as you can with a sawzall or hacksaw and then drill it out with a holesaw. This would give you a nice clean hole for the new pin.
/ Advice Please On Removing JD Quick Attach Pin #31
You won't be able to grind that flush weld and bang it out. If you look at the new pin, there is an angle on it. So you weld your way out as you fill in that angle. What does the broken side look like? Can you drill from the other side? Start small and go bigger and bigger.
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2021 Case TV450B (A64126)
2021 Case TV450B...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
2022 EZ-GO ELITE...
