K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,917
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
Nice Bob! Let us know how you like the Piranha.
O man we love those piranha bars here wonderful products, btw love your airstream.
I've had a ptb on my 3520 almost since new.
This time of year, I can uproot much brush and many smaller trees with it because the ptb's serrations will bite and grab onto the trunks, they either just get pulled out as I drive forward or I curl the bucket and up they go.
Definitely helps with digging in as well, probably because the initial bite into the dirt is concentrated in a smaller area.
Last but not least, it makes an awesome looking bruise when you smack your shin into it.
The only drawback I've found is that my clamp-on trailer hitch doesn't fit perfectly with it on, and I can't be arsed to take the ptb off to use the hitch for three minutes, so I tolerate it swinging a bit. Also, the ratchet rake doesn't fit over it. This is only a minor concern because though I bought both at the same time, I've found the back-dragging (gently, of course, let's not get into that here) with the ptb accomplishes enough that I almost never use the RR... though that's partially because I have to remove the ptb to use the rr, of course...
Well on the upside, it should only take a couple of shin whacks from the tooth bar to teach you to lower the bucket all the way to the ground.
Just a shade structure I built from unistrut/superstrut. It gets over 100 degrees pretty routinely during the summer. The trusses are simple triangles with gusset plates at each corner. The purlins are pressure treated and the sheathing is polycarbonate. I'll see if I have a picture which gives a better view.Out of curiosity, What is that structure for that is above your garage, Bob?
