Like many others I am looking at the LX series. Specifically, the LX2610HSDC (Cab). I'd be interested to hear from current owners regarding their experience so far with the LX series. Any LX2610 owners who wish they had bought the LX3310?
I have no experience with the LX but in my mind HST whine is like the refrigerator running. If you think about it, it’s gonna annoy the crap out of you. If you just do whatever you’re doing it’s white noise. The LX owners are likely new to tractors so hyper sensitive to any sounds. Just my opinion.Thanks Ralph. One guy on YouTube, GP Outdoors, has some good videos, but what do you think about the HST whine he complains about?
I don't know what you guys are doing to complain about lack of power. I started out with an 18.5 hp JD and had it for 9 years. Plenty of power for bush hogging/mowing and wood chipping.When the weather is colder than about 40 F my 2610 is a little jerky until the fluid heats up a little. No problem for me, but I don't use it when it's too cold outside for the fluid to get warm. That weather doesn't exist here.
I like the machine quite a bit, just wish I had bought more HP. Didn't want the weight of a L to mow with, but now that I have the ZT not needing the tractor to do much of that.
I have an LX 2610 with the SU tires and 1.5" rear spacers, filled rear tires. Very stable. You can't use a MMM with the SU tires, even though it has the mid PTO. A MMM weighs over 300 # less than the RFM I had, but that wouldn't be enough to solve the lack of power problem for me.
I'm wondering how big a load the climate control is putting on the engine...I think in a car it's 2-3HP mathematically. BX23 is 1,570#, LX2610 is 1,786 so that cab also adds about ~13% to the base tractor weight. Adds up quick when you're applying the load to a small engine.I don't know what you guys are doing to complain about lack of power. I started out with an 18.5 hp JD and had it for 9 years. Plenty of power for bush hogging/mowing and wood chipping.
Do you like to operate always below 1500 rpm?
It LX2610 not LX2601. Only mention as there is a B2601 so dont want to confuse anyone.One video on the LX2610 was done by a guy who had owned a B2601 previously. He mentioned that the LX's treadle pedal was a bit jerky vs. his B2601's being butter smooth.
That's why I want to try them out, with loaders. Looking at a B2301 or LX2601. So far, 3 dealers have the tractors but no loaders.
Everything is relative. You are happy because you took a step up in power. The most disappointed guy here downsized from an L series.I don't know what you guys are doing to complain about lack of power. I started out with an 18.5 hp JD and had it for 9 years. Plenty of power for bush hogging/mowing and wood chipping.
Not sure where you got those specs on the lx2610 lift. You better verify them before you buy. If not, you're going to be in for a BIG surprise.This is really useful. I'm worried about the HP too although I've done my homework and at least on paper it should work. I'm trading in my B2620 to get it. Here is the comparison:
B2620 24.3 HP (engine gross)
PTO 19.0 HP
Lift Capacity 1356lbs at lift point and 1058lbs at 24"
LX2610 24.8 HP (engine gross)
PTO 19.5 HP
Lift Capacity 2139lbs at lift point and 1676lbs at 24"
So on paper the LX2610 is a little stronger and has a lot more lift capacity which is hard to believe. My land is flat and my B2620 does what I need: It fits comfortably in the rows, handles a 60" RFM and a 3pt mounted sprayer. My problem is I need a cab. It's hot here in the summer and wearing gear is getting old.
I have a larger tractor with loader for heavy work. The reason I'm concerned about HP is the mower and tiller I use call for a 20 HP at the PTO. I don't know if I should be cutting it that close.
Not in and out, you can not turn it to line the splines up.What do you mean your PTO shaft has no free play? It is cut to the proper length I hope?
