Loader joystick cable break
/ Loader joystick cable break #41
On my 8050 there are about a dozen screws to remove to get to the joystick bolts (2) and then the cables are screwed into the block with lock nuts. The lower valve end has a cover with two or three small bolts then the cables are held to the spools with a small clevis which is screwed to the end of the cable, the cable is secured to the valve mounting block with a pair of nuts that are also used to adjust the overall cable length. I also remove the cab step on the right side of the tractor to be able to reach it easier.
On the 3520, the joystick is just hanging out there on the fender, to get to the bolts you just have to remove the cover. The step isn't in the way but lots of other stuff is. See next post for more details.
OK, if anyone is still interested. [Please excuse, I'm writing this partly as a way to make sure I'm thinking through it correctly.] I redid the tube with hose clamps fix, I had thought I ought to have the slots on the ball assemblies lined up with the lock thinking that was the rest or neutral position so maneuvered everything to where I could push the lock in. I went with 5 clamps just trying to make sure. And it didn't work, but it was different, it felt like it was working, the hard stop thunk you could hear in the video when I moved the joystick all the way to the right was gone but I got zero movement of the bucket.
The wires in the cable sleeve that had escaped the ferrule were really hard to get back in and I'm still confused how they slipped out, it had to be during my first attempted fix. At some point when testing the fix, the bucket had to have uncurled for the cable wires to move out enough to get past the end of the ferrule, and the bucket was curled out to some degree, I must have missed it at the time. From what I can figure out, the only way to for manufacturing to build the joystick/valve/cable system would be to screw the cable assemblies into the joystick before the other ends are secured. See still from Short Line video, what she calls the bonnet isn't fixed to the sheathing as it is on the joystick end where you have the analogous ferrule as we've been calling it. The available adjustments would then be there at the valve end with the bonnet, is that right?
trx-cap --  - 12_6_2021 , 06_53_34 - How To Connect Joystick Cables to Valve Spools - Covered ...png
Basically, screwing the bonnet in and out changes the distance from joystick to valve as constrained by the sheathing. So the first test must have moved the control to some extent but mostly just pushed the sheathing out enough to escape the ferrule, then, when I pushed left to curl bucket in, the wires moved past the end of the ferrule. This is where I think those turnbuckles might be needed. Cougsfan do you remember if you needed to pull in the sheath with the turnbuckles?
See the photo:
The one on the right is the way it is now at rest, the slot is no where near where the lock slides in. The one on the left is with the bucket full-left and the slot still isn't quite out enough for the lock to engage.
So my thinking is to loosen the clamps, push the joystick all the way left, then tighten the clamps at that position. If that works to some extent, isn't it going to be the case that it would only be luck if the joystick behaved properly? I will have to adjust the cable at the valve end regardless? Like locking, you only lock when it's centered/in the neutral position, so it would only be luck if they lined up now?
/ Loader joystick cable break #44
Yes the bonnet is how you adjust the amount of free play in the cable. Screwing it out effectively makes the housing longer which since the cable stays the same length, would reduce cable free play.
I'm not sure I understand the 'free play' thing. This is my naïve thinking: The valve side is normally 'off' as in no flow, so you need the rest/relaxed/centered position on the joystick to set the valve to that position, and if, like in my case,, the setup gets screwed up, you could have the joystick in neutral position pushing or pulling the cabling in such a way that it tells the valve to turn flow on. Am I missing something? I hope that ain't too stupid a question.
/ Loader joystick cable break #46
You got it. Center position on the valve spool is off. You want the joystick to be in the center then as well. If for example you made the housing an inch longer with the same cable, center on the joystick would pull the cable and the spool an inch from the center position.
If your repair does not push the housing as far into the ferrule as it was before, then you need to turn the bonnet to thread more of the threaded ferrule into it.
/ Loader joystick cable break #47
If OP has a multi gear bicycle, it’s easy to play with and see how “lengthening” and “shortening” the total “sheath” length (by adjusting the length/position of the ferrules it attaches to) adjusts the length of the cable that comes out the sheath (and ferrule).
Thus, it determines how the handle end position “aligns” with the valve end position. That neutral position at stick end = neutral position at valve end. (Or with a bike: That 2nd gear on shifter also equals 2nd gear on the rear cassette.)
Like others said: If repair altered total sheath and ferrule length, adjustment with bonnet is required to obtain original total length so that stick positions are is similar to original positions.
/ Loader joystick cable break #48
When I replaced the cables on mine I set the joystick ends of the cables so the "lock" would latch into the two cables and then secured those ends, then went to the valve end adjusted the clevis ends to line up with the pin holes in the spool ends. That was by adjusting the two nuts that retained the cable at the valve mostly with just a bit on how I screwed on the clevis ends..
Thanks guys. After much fiddling, I could not get the hose clamps to work, the sheath kept slipping. I killed 2 or 3 clamps so maybe I need stronger clamps but those were pretty decent. So it's on to the more drastic solutions of epoxy or weld/solder/braze. They will require I take the control cable out so I've got that to look forward to.
Well, I was just taking another look at Cougsfan's photo and it made me think maybe the tubing might have been the weak point, it would be plastic on plastic on the sheath side and that was always what slipped and I used 2 clamps just on the sheath end that I'm pretty sure were bigger and beefier than the one he used. That warrants another few tries without the tubing. I've got things I have to attend to the next couple of days so it will be a bit before I can get back to it. I also belatedly realized if I get new cables, as long as they're long enough, too long isn't that much of a problem within reason, it would just mean routing it differently to take up excess.
Thanks again all.
/ Loader joystick cable break #50
If you add bends to the cable routing that will add friction. That may be better than a non working loader though!
🥨I wasn't thinking pretzel, more like spiral with occasional bow or maybe bowier
trx-cap --  - 12_7_2021 , 05_11_27 - S__Documents_propery search_tractor_Striped_bodysuit_for_...jpg
The 3520's configuration has fairly short cables but those cables work fine in much longer versions so there's likely a large margin of excess friction to work with.
Just after waking, I was pondering the issue and I thought maybe not use a clamp at all, wrap wire around the cable directly, maybe use the tube with clamps to hold the wire more securely. It doesn't help that the bottom of the joystick housing is so close to the fender that the cable has to bend the way it does, likely helped to cause the problem in the first place, see photo. There's something about having all those hose clamps that kinda screams desperation. And I'm really slow on the uptake, I'm looking at the photo and just now realize I shoulda had the plastic tube up around the threads a ways [insert favorite facepalm here].
/ Loader joystick cable break #52
Wow, Mechtheist, I am sorry you are having such a difficult time. One of the problems of describing all this is that all of us seem to use a little different terminology for the parts. Plus there are a lot of parts involved.
If, with your hose clamp fix, the sheath was not moving and it still didn't work, the problem must be in adjustment. If those wires on the sheath didn't go all the way back into the sleeve before you installed the hose ands clamps, the cable would not activate the controls in the push mode. The overall cable adjustment and movement range would be out of whack. That can be adjusted out at the bottom.
So was the sheath moving when you move the joystick? By the way, much smaller hose clamps available, which would work and look better and the plastic tube could indeed be much longer both directions to give better hold. But I agree the whole thing will look rather Rube Goldbergish.
I think you are correct in assuming that you can't get the cable completely disconnected at the top without disconnecting the bottom.
It hasn't been all that bad, there's a lot worse problems it could be. I got all the wires on the sheath back in the sleeve and it was definitely moving when I moved the stick to the right and then back in when I moved it to the left. I had all those clamps on there and cranked about as tight as they would go and it still slipped. I'm thinking the plastic tube was less gripping than your hose clamp alone, the overall cable has that kind of ribbing [for her pleasure I'm sure] that would really help the hose clamp stay put but I think the tubing was allowing them to slide over the ridges. I was thinking one of these things might really be ideal but not sure if I could find one the right size:
And there are hitches [knots] that are good for that kind of thing, like self-tightening, if I can't get the hose clamp and wire to work. I had doctor appointment today but they cancelled on me so I'm off to the Home Depot to see what I can find. You think smaller hose clamps would be better? Performance wise I mean, at this point, appearance isn't a concern though I am trying to figure out a way to get duct tape involved or else it just won't seem a proper repair.
/ Loader joystick cable break #54
Maybe you could use stainless safety wire to grip the housing and keep it from pulling out. I'd use .035 or .040 wire and twist the heck out of it with safety wire pliers to get it tight on the housing, then run the wires up to the threaded part and tie them off around it. Then do that a few more times. The hard part would be to get the wire tight. But if you backed off the adjuster on the valve first then you could tighten it after doing up the wires.
/ Loader joystick cable break #57
You are right, if it were to be crimped it would take a circular crimper that crimps the entire circumference. That particular crimper's largest die is a 2/0 AWG which is slightly over 3/8" which is much too small for this sleeve. Perhaps a hydraulic shop could re-crimp it? That sleeve is pretty darn solid though, I am not sure even a hydraulic hose crimper would work.
Thanks again for all the input. Crimping might still be an option, Popgadget, that looks like a good tool for a great price, but I still have to get the cable out of the valve...
Yesterday I wired and turnbuckled and hose clamped and got nowhere. With it wired up as best I could I tried grabbing on to the sheath and trying to shove it in as it was getting shoved out and the way it felt made me think there just wasn't any way it was gonna work, like the control 'rod' and sheathing were one piece, not any play at all, solid. That made me think maybe there's something going on at the valve end like maybe it was frozen or ??? So I had to do what I maybe should have done from the beginning--take the cable off the valve and all I can say is ef me! See all the pics.
I took the plate with the red hashes off and even unbolted the valve body but that really didn't buy me much room. The thing behind the cables is the large upright support for the loader and has a large gusset in back. I didn't even know until messing with this that that's part of the fuel tank there to the left of the valve.
Two of the 3 bolts holding the valve on with the one having some weird corrosion, I assume it's water getting in there?
Below is what I'm looking at trying to remove the cables, I managed to get the allen screws out of that collar thing but it was not easy and I was lucky they were not very tight. That was the end of the luck. See below pix. I know I'm not much of a mechanic but I don't see how anyone could remove the control cables without unhooking the two hydraulic cables that are perfectly placed to thwart that. The Short Line video is great for showing what to do but nothing needed a wrench and here I need two and can't get one in there. Am I missing something? The number of folks here talking about removing their cables didn't mention having to get the hydraulic lines out of the way, is that something specific to the 3520?
They're not QD so I'm looking at some hydraulic fluid loss, right? The top line is the one to the rear hydraulics and the other is to the drain. The drain would go the tank which is lower and shouldn't siphon but I'm not sure about coming from the rear valve, how much would flow from there and if I kept the end up would that minimize fluid loss to some percentage of what's in the line? It's about time to change all my fluids and I'm getting a diverter valve multiplier thing for a hydraulic top link and maybe something else [am going to post a thread about that soon] so I can do all of this at same time and not worry about fluid loss.
The last 2 photos show more weird corrosion on the couplers on the line to the rears. I didn't notice until I looked at the pictures but if that isn't maybe plant matter that got caught up in there, then what is that? It's the same color as the corroded bits.
Still not sure what I'll find with the cable fault, hoping it's not the valve as that's likely to get ugly. I'll probably buy a new cable since I've gone this far. eriicm979, now that I've gotten a lot more familiar with all of this, that cable might be long enough, if not, it won't be all that much shorter than what I'll need.
Ah well, Onward Thru the Fog! And thanks for all the help.
/ Loader joystick cable break #59
When you get the jam nut on the top of that sleeve loosened, then unscrew the nut till it will slide along the cable.
Then sleeve will then unscrew back away from the valve and over the cable also to expose how the inner cable is secured to the valve spool.
When? It's more like 'how'. I can't get two hands in there, can't get two wrenches, unless it's finger tight, which it didn't seem to be, it's not gonna happen without more access. If I try to turn it, the whole assembly rotates fairly easily. I'm basically resigned to having to remove at least one probably two and maybe all 3 of the non-QD hydraulic lines, I'm just not very happy about it. I'm figuring it's going to be very messy and there'll be no end to the expletives.
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A64194)
1987 Fruehauf MC...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2007 Lexus RX 400H (A64557)
2007 Lexus RX 400H...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
