MT225S rear ballast ??
/ MT225S rear ballast ?? #1
kormidoit
Lake Almanor, CA.
2021 LS MT225S, 2003 Kubota BX2200
So we are coming into snow season and I will be loading snow and moving it to an empty lot across the street....I have taken off my backhoe for the winter, my MT225s has loaded tires from dealer, so do I need to add real ballast ?
/ MT225S rear ballast ?? #2
Try it without ballast. If you have any issues, just stick an implement on the back (backhoe may be a little cumbersome )
Got it.....I have no implements at this time but will give it a try. Thank you.
/ MT225S rear ballast ?? #4
If you need to put the backhoe on for weight, you can. I would just be worried about backing into something.
So another question is its ok.... 3 point attachment is on now.....isnt the down lever suppose to apply pressure going down or just gravity fed ? I have lift pressure but not downward pressure.
/ MT225S rear ballast ?? #6
3pt is just gravity; no down pressure.
Excellent....I have the hydro lines fitted properly then. Again...Thank you.
/ MT225S rear ballast ?? #8
I have never seen a 3 point system that has down pressure but that doesn’t mean there aren’t any.
As far as hauling snow in you FEL bucket I don’t think that will be a problem because snow isn’t very heavy, just be a little extra careful the first few trips.
/ MT225S rear ballast ?? #9
As others have stated, you might need ballast, but try to plow without it.
Do you have hills?
What is your driveway made out of?
The reason for these questions is chains. If you have hills, and I mean, slight hills, your tractor will benefit from wearing chains. But if your driveway is paved concrete, your chains would will put little dimples all over it. Asphalt, wouldn't worry about it. Gravel, go for it. I have filled tires and chains. But my driveway is steep and made of gravel.
The amount of ballast in your tires is negligible. It's better than nothing, but those tires dont weigh much. Just looked up the tire size and the Rimguard tool, your tires filled weigh ~170lbs per tire. Thats not much. But again, better than 0.
My best advice is to run what you have. You will learn very quickly if what you have is adequate. If you feel you need more weight, put your BH on and try it. If you feel like all you do is spin, take a look at getting chains.
/ MT225S rear ballast ?? #10
This in my first snow season with my LS tractor as well. Dont we want to use the "float" function on the FEL joystick when plowing??
On my FEL joystick there's a little lever in the front at the base of the joystick I just drop the bucket and angle it the way I like and pull out the float function lever??
Rear ballast - on incline probably need something. Try not to drive on the driveway before you plow so you dont make ice tracks/compacted snow. I did that last year and the ice was there to stay for a month or longer.
/ MT225S rear ballast ?? #11
Most of the time, yes. You will want the bucket cutting edge flat to the surface, put in float, and monitor the bucket. It's easy to catch an edge and start digging into the surface. If your paved, probably not a huge deal. If your gravel, then that could be bad.
To put your FEL into float, simply push forward on the joystick all the way past the detent. That is float. The lever on the front of the joystick is the joystick lockout. You wont be able to move the FEL when that is locked. FYI.
Do you have hills?
Driveway is concrete...goes from flat / slight to 6 degrees. Second house is assault driveway with shorter but 6+ degrees to road ( 500 yards between houses ). YES..... I have chains....thats why I purchased them and the 2" Rear Spacers to clear frame with backhoe attached. I have run chains on my Kadota BX for the 20 years....not worried about slight damage to driveways.
"170lbs per tire. Thats not much." 🙃😁 Avenger....I'm 6'1" 220lbs...66 years young. The friggin chains are heavy to me.(y)😀. In you opinion...would a 5 gallon bucket with cement be sufficient IF NEEDED ?? Want to thank all of you with ur options....this forum is the BEST.
Bobrown....I agree on the 'float" function if I was plowing....however I have to move snow with the bucket loader. FYI the little lever LOCKS the FEL stick from moving....be careful. If you want to get 'ice' off ur driveway....nothing better than the cutting blade on the from bucket....again be careful of stress gaps.... some of mine have a slight height difference and will catch the bucket....ouch. Gotta grind those down next year. 🙃
/ MT225S rear ballast ?? #15
If you're running chains, I dont think you need any ballast. Your not using your FEL to lift heavy loads. The tractor, with filled tires, and your 220lbs will be enough to stick to the road quite well. If you're lifting heavy objects, then you'll probably want something more on the back. A 5 gal bucket of concrete weighs about 100lbs. But if you move it back, leverage will help. But I really dont think its necessary. If you got a 30 gal container, maybe a 30 gal drum, that would give you about 600 lbs on the back. Thats heavy. Your tractor can lift about 1900lbs on the lift arms. But again, I'd plow, with the chains, and see how it does.
2019 ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
2019 ALLMAND...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
Ford 3430 Tractor (A65579)
Ford 3430 Tractor...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
