etpm
- Joined
- Jun 30, 2021
- Messages
- 2,388
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
This tractor is my first diesel. Yesterday when I started it the temp was 40 degrees, or maybe a few degrees cooler. So not too cold. Following the instructions in the manual I turned on the thermostart for 10 seconds. Well, at least the thermostart light was on. With the throttle set for about 2000 RPM I pulled out the compression release knob, cranked the engine and let go of the knob. It almost started. So I tried again without the thermostart. It started but died as soon as I stopped cranking. So I tried a third time. I just cranked the engine until it started, about 7 seconds, which seemed like a really long time. White and black smoke, then just copious amounts of black smoke came out of the stack but it was running. I throttled down to 1500 RPM and it sounded fine and did not smoke. The smoke really only lasted two or three seconds, I could tell it was just unburned and partially burned fuel. Once started and with the RPM set to 1500 it sounded normal and didn't smoke. Tomorrow I will test the thermostart to make sure it is working. But did I do anything wrong trying to start the thing? At 50 degrees it starts right up without the thermostart. I was wondering if actuating the thermostart just dumped diesel without igniting it, and that's why I saw white smoke and then lots of black smoke. Because the engine was flooded. Anyway, tomorrow I'll check the thermostart and then I can know a little bit more.
Thanks,
Eric
Thanks,
Eric
