Hand winch on the utility trailer installed
/ Hand winch on the utility trailer installed #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
I had a real problem loading a couple non operational riding mowers to my utility trailer without a winch a couple weeks ago.
The mower has flat front tires that cause it to roll so hard.
It was too hard to do by myself.
I should have had this winch on the trailer a long time ago.
Hope this video helps someone who needs to do so...
John's Ranch
/ Hand winch on the utility trailer installed #2
You'll never have a dead battery or poor wiring connection.
Bruce
/ Hand winch on the utility trailer installed #3
I made an adapter for my 1/2" 20v cordless drill, to run a winch like that.
It works very good, and takes a lot of the work out of it.
SR
/ Hand winch on the utility trailer installed #4
Great solution! Sure saves your back for loading stubborn items.
I use this portable drill powered winch from Warn:
It's handy for a variety of pulling tasks. I've even pulled my tractor out of a snowbank with it.
SR
Is it possible to upload some pictures for the adapter?
Thank you in advance.
John
/ Hand winch on the utility trailer installed #6
John
It's very easy to do...
I started out with a couple of pieces of electrical conduit. I cut one to length and took a couple hammers,
pounding one end oval, until it fit on the end of the shaft where the winches handle went,
Then I split a second piece, slit it over the first piece to "double it", and welded them together where I had made the split, for extra strength.
Next, I took a piece of all thread and spun two nuts on it, mig welding and grinding the one I spun to the bottom/end, round so it would fit down the tube,
The second nut I welded higher on the all thread, and drilled a hole through the conduit to weld it and the nut in place, to the tube.
It's strong and works VERY good,
Lots of ways to skin a cat, I just used what I had lying around...
SR
SR
Thank you for the pictures.
I just made my own adapter from your inspiration.
The plate is 1/4" left over from the last project and doubled for more strength.
The 3/8" extend bar and socket that came from recycled
Tested with my 18V ryobi drill that is not strong enough to pull the riding mower..
I might need 20V drill.^^LOL^^
Thanks Again
John
/ Hand winch on the utility trailer installed #8
I've had several people tell me a cordless drill won't work, not enough power...
BUT, they have china winches, mines American made, and it's geared a bit lower, works smoother, and also has a hi-lo, so my drills have plenty of power to run it.
SR
/ Hand winch on the utility trailer installed #9
Thanks Again
John
If I'm guessing right, your drill is a 3/8th incher. They typically lack the torque of a 1/2 inch. I've been watching this thread with great interest. Last summer I had occasion to use my trailer to haul home my Town & Country mini-van because the starter wouldn't engage (corroded terminal as it turned out). I'd lost the crank for the winch so I ended up using an open-end wrench a quarter turn at a time to load that heavy beast! A 1/2 inch cordless drill may not have been enough muscle even on the geared down drive I used the wrench on. I'm wondering how a heavy duty impact wrench might serve.
/ Hand winch on the utility trailer installed #10
My DeWalt 20v, 3/8's drive will run my winch, but since then I bought a half incherer...
Also, brushless tools have more power, are lighter and the batts last longer, that's all I buy now...
SR
DRAGON TRAILER MOUNTED TRANSFER PUMP (A60736)
DRAGON TRAILER...
Case SV280B (A60462)
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2017 FREIGHTLINER CASCADIA WRECKED (A60736)
2017 FREIGHTLINER...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
