Hand winch on the utility trailer installed
/ Hand winch on the utility trailer installed #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
I had a real problem loading a couple non operational riding mowers to my utility trailer without a winch a couple weeks ago.
The mower has flat front tires that cause it to roll so hard.
It was too hard to do by myself.
I should have had this winch on the trailer a long time ago.
Hope this video helps someone who needs to do so...
John's Ranch
/ Hand winch on the utility trailer installed #2
You'll never have a dead battery or poor wiring connection.
Bruce
/ Hand winch on the utility trailer installed #3
I made an adapter for my 1/2" 20v cordless drill, to run a winch like that.
It works very good, and takes a lot of the work out of it.
SR
/ Hand winch on the utility trailer installed #4
Great solution! Sure saves your back for loading stubborn items.
I use this portable drill powered winch from Warn:
It's handy for a variety of pulling tasks. I've even pulled my tractor out of a snowbank with it.
SR
Is it possible to upload some pictures for the adapter?
Thank you in advance.
John
/ Hand winch on the utility trailer installed #6
John
It's very easy to do...
I started out with a couple of pieces of electrical conduit. I cut one to length and took a couple hammers,
pounding one end oval, until it fit on the end of the shaft where the winches handle went,
Then I split a second piece, slit it over the first piece to "double it", and welded them together where I had made the split, for extra strength.
Next, I took a piece of all thread and spun two nuts on it, mig welding and grinding the one I spun to the bottom/end, round so it would fit down the tube,
The second nut I welded higher on the all thread, and drilled a hole through the conduit to weld it and the nut in place, to the tube.
It's strong and works VERY good,
Lots of ways to skin a cat, I just used what I had lying around...
SR
SR
Thank you for the pictures.
I just made my own adapter from your inspiration.
The plate is 1/4" left over from the last project and doubled for more strength.
The 3/8" extend bar and socket that came from recycled
Tested with my 18V ryobi drill that is not strong enough to pull the riding mower..
I might need 20V drill.^^LOL^^
Thanks Again
John
/ Hand winch on the utility trailer installed #8
I've had several people tell me a cordless drill won't work, not enough power...
BUT, they have china winches, mines American made, and it's geared a bit lower, works smoother, and also has a hi-lo, so my drills have plenty of power to run it.
SR
/ Hand winch on the utility trailer installed #9
Thanks Again
John
If I'm guessing right, your drill is a 3/8th incher. They typically lack the torque of a 1/2 inch. I've been watching this thread with great interest. Last summer I had occasion to use my trailer to haul home my Town & Country mini-van because the starter wouldn't engage (corroded terminal as it turned out). I'd lost the crank for the winch so I ended up using an open-end wrench a quarter turn at a time to load that heavy beast! A 1/2 inch cordless drill may not have been enough muscle even on the geared down drive I used the wrench on. I'm wondering how a heavy duty impact wrench might serve.
/ Hand winch on the utility trailer installed #10
My DeWalt 20v, 3/8's drive will run my winch, but since then I bought a half incherer...
Also, brushless tools have more power, are lighter and the batts last longer, that's all I buy now...
SR
/ Hand winch on the utility trailer installed #11
Same over here!! I wait for them to go on sale - usually for about 130$ Canadian. When I was loading the T&C that time though I doubt it would have handled it. Thats why I'm thinking of trying an impact tool next time I'm loading something heavy.
My drill is 1 /2" and quite powerful torque also; the hand winch has a dual gear ratio. One is 4.1:1 and the other is 9.8:1.
This morning, I tried to pull the riding mower into the trailer again with the
adapter on low gear. It works pretty well even in high gear too somehow.
However, to pull your minivan (probably more than 3500LB) with cordless drill is doubtful to me too.🤔🤔🤔
Unless the pulling force is less than 1000lb.
Anyway, it was a good experiment
Thanks
John
/ Hand winch on the utility trailer installed #13
Pretty clever anything to help make the job easier, I enjoy fabricating things out of spare parts laying around.
