Kubota M7040 with grooved R4's
/ Kubota M7040 with grooved R4's
Good to hear of your experience with them. It sounds like most people have had similar experiences.
/ Kubota M7040 with grooved R4's #22
Does anyone have any up-close pics of grooved tires?
/ Kubota M7040 with grooved R4's #23
Best pic I have is the one I posted at the beginning of this thread.
Here are a couple pics of the results on dirt.
Cool! Been noticing the tracks I've been making in the snow too.
/ Kubota M7040 with grooved R4's #25
The results look very professional.
/ Kubota M7040 with grooved R4's #26
Kind of a sidetrack, but I read a paper concerning tire traction in snow several years ago.
Tire traction in snow is created by trapping snow in the tire treads, then scuffing that trapped snow against snow on the ground. The friction between the two creates traction. Thus, a tire with multiple sipes and tread angles will fill with snow quicker, and create more traction. When the tire rotates and the portion of tread filled with snow elevates off the ground surface it will flex and throw out the trapped snow. As that portion of the tires again makes contact with the ground it will trap snow, scuff it against the snow still contacting the ground and create traction. This principle is also why Radial tires will always provide more traction than bias tires with the same tread pattern. Radials control the tread face of the tire better than bias tires. The tread of the radial flattens itself on the ground, which closes the gap in the tread, which fills and grips the snow. That is evident when you watch a vehicle drive off with Radial AT tires. They are full of snow and toss it off as they rotate.
Sorry for the lengthy description. It's rather complicated....
Honestly, unless you fall asleep in mid-cut, it's pretty easy to have good results. It's not perfect but somehow still looks pretty consistent.
Not lengthy at all. It's a great explanation of how it actually works.
/ Kubota M7040 with grooved R4's #31
I was going to link my post, but I see it was already done! No regrets here at all.
Good thread LittleBill....it was even colder when you did yours!
/ Kubota M7040 with grooved R4's #33
yea dude it legit sucked. took me like 3-4 hours. my arm was done for about 3 days lol. I am so lazy
Lol, I feel your pain
/ Kubota M7040 with grooved R4's #36
I have a cutter that looks like an old school soldering iron with replaceable cutters. It sucks.
My friend has a cutter that only gets the tip hot when you push it against a tire and activate it. Will instantly melt a cutter if you don't have it moving thru the tire when activated. Cuts the tire like cutting soft butter. I used it to cut all four of my rock crawler tires. No sore arms. Ended up with 3 gallon of trimmings.
/ Kubota M7040 with grooved R4's #38
If the chance happens, could you take a couple more close-up pictures from different directions? This is very interesting and your work looks very professional.
/ Kubota M7040 with grooved R4's #39
Sorry Six, I sold that tractor. Sorry.
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A60352)
2013 Chevrolet...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2024 GMC Sierra Elevation Crew Cab 4X4 Pick-Up Truck (A60352)
2024 GMC Sierra...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
Electric Concrete Mixer (A61166)
Electric Concrete...
