John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,768
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
Most injuries above the waist are to the left hand. I don't have the exact data, but I suspect there are two main sources: injuries to the thumb/hand/wrist from kickback (usually a sprain or dislocation, rather than a cut) and injuries from improper reaching for the chain brake, allowing the hand to come in contact with the chain. (for the later, the recommendation is to activate the brake by bumping it with the wrist while still holing the handle, and release by keeping the left thumb hooked around the handle and reach forward with the fingers to pull the brake handle back.) If you just figure out the left hand, that accounts for over 75% of the upper body injuries.Not sure how the "50%' injuries above the waist are happening.
On my "one day I'm going to" list is to buy a pair of safety-toe boots. Not only have I managed to smash toes, but recently I scratched the top of one of my boots with my saw (it was like it was saying to me: "hey! did you forget that you were going to buy safety-toe boots?").
Remember there is more to protecting your foot than just getting a steel toed boot. A steel to alone can often just cause the chain to "skate" along the top of the steel until it drops down behind the steel toe, dicing up your metatarsal bones (the ones behind your toes). If you are going for foot protection, go for true chainsaw cut protection, and one comfortable enough that you will actually wear it.
I've had good luck with my Haix XR200 chainsaw boots. They are very comfortable - as good as the best pair of hiking boots I've ever owned. When these do finally wear out, I'll probably switch to the Haix Protector Ultra boots - a higher class of cut protection, a tread pattern that gives a bit better traction, and about 1" taller.
