JD X570 - what is this rubber plug?
   / JD X570 - what is this rubber plug? #1
bkfz1
John Deere X570
Howdy Folks, I was cleaning my new JD X570 and found this rubber plug with a metal washer in the grass under the tractor after blowing it off.
I'm about 98.9% sure it's from the tractor, but wouldn't stake my life on it... It's about 1 inch long.
Any idea where it belongs on the tractor?
Best,
BKFZ1
   / JD X570 - what is this rubber plug? #2
Look at the plastic skin for a missing holder. ( a hole with nothing in it. )
Thanks! Found it - it was so obvious I missed it several times 🤪
   / JD X570 - what is this rubber plug? #4
Best,
BKFZ1
Engine oil drain plug?
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
2017 FREIGHTLINER CASCADIA (A50854)
2017 FREIGHTLINER...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
TRUCKING INFO (A50774)
