JD X570 - what is this rubber plug?
   / JD X570 - what is this rubber plug? #1
bkfz1
John Deere X570
Howdy Folks, I was cleaning my new JD X570 and found this rubber plug with a metal washer in the grass under the tractor after blowing it off.
I'm about 98.9% sure it's from the tractor, but wouldn't stake my life on it... It's about 1 inch long.
Any idea where it belongs on the tractor?
Best,
BKFZ1
   / JD X570 - what is this rubber plug? #2
Look at the plastic skin for a missing holder. ( a hole with nothing in it. )
Thanks! Found it - it was so obvious I missed it several times 🤪
   / JD X570 - what is this rubber plug? #4
Best,
BKFZ1
Engine oil drain plug?
CONIBEAR EQ. HYD SEED SPREADER, 3PT (A57192)
CONIBEAR EQ. HYD...
2011 BMW 750Li (A55973)
2011 BMW 750Li...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A57024)
NEW 2025 Load...
