Kioti dk40se 2nd rear remotes?
/ Kioti dk40se 2nd rear remotes? #1
Brozum01
2013 kioti dk40se hst
Does anyone know where to buy a 2nd rear remote kit for a dk40se?
/ Kioti dk40se 2nd rear remotes? #2
Did you try Michigan iron and Equipment?
No I haven't. Thank you. I know I couldn't find anything searching online
Told you where on the other forum you posted on. Got the same answer here...Dealer only.Just asking a question.
Just asking about question. Sorry you had to see it twice
/ Kioti dk40se 2nd rear remotes? #6
I'm not but I answered you on the other forum. It's a dealer only item unless you can find them at a tractor salvage place. People post on multiple forums, same question. Like a fishing expedition sort of. You might try MidWest Salvage or look on Tractor House. Like I said on the other forum, they won't be cheap. I know Kubota is right around a thousand bucks per set.
/ Kioti dk40se 2nd rear remotes? #7
If Michigan Iron, can no longer get it, which is a very good likely hood, you can go with a diverter fairly easy enough at or around $500. Shop around, Summit would be the first place to check, but there are others both higher and lower in costs. All depends on what you want-get.
Hopefully MIE has or can get the OEM valve for you. (y)
/ Kioti dk40se 2nd rear remotes? #8
There is another Kioti dealer in Monroe, Michigan, J&R Equipment that can get them (if available). Parts manager is Named Dave, good guy, know him personally. Might have a set in stock, worth a call. 1-734-241-3232
The issue with Kioti remotes is like Kubota, they stack with a common feed.
