Kioti dk40se 2nd rear remotes?
   / Kioti dk40se 2nd rear remotes? #1
Brozum01
2013 kioti dk40se hst
Does anyone know where to buy a 2nd rear remote kit for a dk40se?
   / Kioti dk40se 2nd rear remotes? #2
Did you try Michigan iron and Equipment?
No I haven't. Thank you. I know I couldn't find anything searching online
Told you where on the other forum you posted on. Got the same answer here...Dealer only.Just asking a question.
Just asking about question. Sorry you had to see it twice
   / Kioti dk40se 2nd rear remotes? #6
I'm not but I answered you on the other forum. It's a dealer only item unless you can find them at a tractor salvage place. People post on multiple forums, same question. Like a fishing expedition sort of. You might try MidWest Salvage or look on Tractor House. Like I said on the other forum, they won't be cheap. I know Kubota is right around a thousand bucks per set.
   / Kioti dk40se 2nd rear remotes? #7
If Michigan Iron, can no longer get it, which is a very good likely hood, you can go with a diverter fairly easy enough at or around $500. Shop around, Summit would be the first place to check, but there are others both higher and lower in costs. All depends on what you want-get.
Hopefully MIE has or can get the OEM valve for you. (y)
   / Kioti dk40se 2nd rear remotes? #8
There is another Kioti dealer in Monroe, Michigan, J&R Equipment that can get them (if available). Parts manager is Named Dave, good guy, know him personally. Might have a set in stock, worth a call. 1-734-241-3232
The issue with Kioti remotes is like Kubota, they stack with a common feed.
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
