No sound from radio
   / No sound from radio #1
fruitcakesa
CavendishVT
M6040 JD 450C
The radio was working until one day it wasn't.
It powers up, shows the stations and time but no sound from the speakers.
I pulled the roof off to inspect the wiring. All connections appear intact and the antenna is hooked up.
I am totally ignorant on how to test anything.
Any help out there?
   / No sound from radio #2
You sure there isnt a mute button on radio? My kioti radio has one.
   / No sound from radio #3
Does it have bluetooth? Make sure there isn't a pair of ear buds or other bluetooth device nearby. It may be connected but the other device is turned down where you can't hear it.
Mute is not activated and no bluetooth.
   / No sound from radio #5
Hmm. Than it is either a dead radio or bad wire. But you said you looked under roof and all wires were ok.
im not sure how to test either, except to try and hook another speaker up to the existing wires. Not sure what tester you need to verify a speaker signal.
Like I said in my first post, the radio powers up and shows radio stations, volume and time so I assume, perhaps wrongly, that the radio is ok.
   / No sound from radio #7
Is there a separate connector for output that may have jiggled loose?
   / No sound from radio #9
Just because it powers up doesnt mean its working. It might have dead amp or ? That prevents output. I doubt both speakers would go bad, and if all wiring has been checked, what else could it be.
   / No sound from radio #10
Have u tried turning the mute on-off a few times ?
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
2011 ELITE TRAILER 20 T/A GOOSENECK (A55745)
2011 ELITE TRAILER...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Reel Mower (A55851)
Reel Mower (A55851)
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
