No sound from radio
   / No sound from radio #11
Just a thought but what about the fade for front and back speakers? Most tractors only have two speakers and the radio may be able to have 4. If it was adjusted all the way to the front or back there may not be any sound because no speakers.
Just because it powers up doesnt mean its working. It might have dead amp or ? That prevents output. I doubt both speakers would go bad, and if all wiring has been checked, what else could it be.
Any idea how I can test that?
   / No sound from radio #14
Is it under warranty ? Maybe they will give you a new radio ?
I will have to check that
2010 tractor:cautious:
   / No sound from radio #16
   / No sound from radio #17
You can test the speaker with a 9 volt battery
just touch the wires to it like testing a light bulb
Not sure I'd use a 9V battery though...a AA would be less likely to damage the speaker.
   / No sound from radio #18
The radio in my TC was acting up. The sound would be fine, then it would act like the mute was half on. It really bugged me for a year...then I found what was wrong. I put a small amount of dielectric grease on the headphone plug and worked it in-out a dozen times and have not had a problem since. I normally never use the phones but I was ready to try anything at that point. Now the volume is consistent like it should be.
   / No sound from radio #19
So....does the radio have a headphone jack?
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
2018 John Deere 8320RT Track Tractor (A53485)
2018 John Deere...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A57024)
2-Row Peanut...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
