John Deere keeps blowing starting fuse.
   / John Deere keeps blowing starting fuse. #11
There is a relay under the fusible link I can’t find out what it is for.
This is a good time to obtain electrical schematics or even shop manual for your tractor because this likly will not be the last time you need them. If dealer doesn't have them,they can be downloaded online. Meanwhile maybe someone can tell you where glow plug relay is located. You might try and trace wires back from plugs to see which relay control's them. You should be able to determine if relay is working by watching for amps to fall after a brief period of time.
   / John Deere keeps blowing starting fuse. #13
   / John Deere keeps blowing starting fuse. #14
Follow the wires from the TEMP. Sensor at the neck and unplug it..
I’m going to check it when I get home thank you.
It works thank you all !!!!!!!!
I’ll replace both of the sensors as soon as I can.
   / John Deere keeps blowing starting fuse. #17
Which 2 sensors are you referring to? RE503242 & ?????
   / John Deere keeps blowing starting fuse. #20
Pic #1 is normally the main cause.. I’ve never seen #2 as a problem..
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2019 Ford F-150...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
