M9540 clutch question?
/ M9540 clutch question? #1
JohnnyRoy
Uniontown, PA
Kubota L45, Kubota M9540
The clutch pedal on my tractor was getting tight and was engaging near the top of the travel.
Today I made an adjustment to the free play.
The tractor operates much better with the clutch engaging much nearer to the floor.
It shifts better, no grinding, or unusual noises.
The issue I'm having is that once engaged the pedal does not immediately return to the original position.
It stays at the bottom of the free play area.
I can raise it to the correct position with my foot and it will stay there or if I leave it alone it will eventually correct itself as I'm driving along.
I sprayed all the areas of tension with white lithium grease.
There is a rather large spring right behind the pedal that might be stretched?
My question is: Is there a possibility I could damage something operating the tractor like this?
Thanks
rob
/ M9540 clutch question? #4
Traction clutch control pedal not fully rising to top of travel could possibly shorten life of the dry traction by not allowing pressure plate to apply designed pressure to the clutch plate. This will depend on how far from fully raised clutch pedal is after operators foot is removed from pedal.
It doesn't immediately raise beyond the bottom of the free play area which I think is set correctly.
I can pop it up with my toe or it will come up by itself after a little while.
If I adjust the free play out it raises all the way.
/ M9540 clutch question? #6
You need to replace the spring
You also need to lubricate thebecause you are operating it in a 'half clutch' position and it will ruin the disc in short order. The spring is cheap a new clutch isn't.
You also need to lubricate all the linkage.
Thanks for the info.
I'll order a spring and post back results.
/ M9540 clutch question? #8
Spring can be sourced at about any farm store, don't have to be a Kubota part. I'd be lubricating the linkage first (including the ball joints), I suspect it's more the linkage than the spring anyway.
/ M9540 clutch question? #9
Kubota specs for freeplay is 1-1/12" of movement from the top of the pedal travel to felt engagement.
/ M9540 clutch question? #10
I'll bet that 1-1/12'' is tricky to measure!!:p I'm guessing you meant 1-1/2''
/ M9540 clutch question? #11
Running it without the clutch pedal returned, will most likely cause premature throughout bearing wear...
Just like holding your foot on the clutch, it's does the same thing.
SR
/ M9540 clutch question? #12
SR
I thought most of these newer machines used a continuously running throw-out bearing ?
/ M9540 clutch question? #13
Oh boy is that an understatement ! I had a MF2660 brand new with dorked up [8 speed shuttle shift] clutch linkage such that the clutch pedal never fully came back up. That was made worse by a manufacturing defect where the pedal lever scraped against (and was impeded by) the underbelly of the console. I had no idea there was a problem and being brand new was still on a learning curve with it as well. Result was it burned out the clutch. The tractor had to be broken in half for a new clutch installation at 29 hours.
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
1998 KENWORTH W900L 6X4 TANDEM AXLE SLEEPER TRUCK TRACTOR (A59912)
1998 KENWORTH...
