Where to find this piece
/ Where to find this piece #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
Does anyone know where to find a washer like this
/ Where to find this piece #2
Better picture about the size of the washer.
Good hardware store or machine shop might help.
/ Where to find this piece #3
A washer like what, exactly? The easy answer is any hardware store. Take the old one with you for comparison. If you need more information you should state the diameter of the hole in the center and the outer diameter of the washer. Thickness may be helpful, too. Is it a plain round flat washer or is it bent in some special way? Do you want just a flat washer or a lock washer?
/ Where to find this piece #4
I’ve been to all of my local hardware stores but they don’t have them I believe I’ll have to special order them
/ Where to find this piece #8
Try shock bushings or track bar bushings
/ Where to find this piece #9
If you'd post your location then perhaps folks here who are in the same general area could give you better suggestions?
Fastenal is a company around me that stocks a lot of industrial stuff. There are also bolt and screw businesses. Likely ANY tractor dealer ought to be able to point you toward a local supplier.
/ Where to find this piece #10
I just replaced those mounts on my 1710, dealer wanted near 50 bucks each! I found rubber isolation bushing that work for that purpose on e-bay. Only difference is they have studs and are a slightly taller.
Thanks man that’s actually very helpful I’ve been looking everywhere are you able to remove the studs
/ Where to find this piece #12
No, you can't remove the studs. I couldn't find any mounts similar to the originals especially in metric.
I used them and installed a lock washer and 3/8-16 hex nut. When tightening them up, try to hold the metal part of the mount to avoid damaging the mount.
/ Where to find this piece #13
Try this source for many industrial products.
durometer 40A is a softer rubber than 50A
rScotty
/ Where to find this piece #14
Just use a shock bushing and cut it if you need to. Any parts store should be able to source one. Tell them you need upper shuck bushings for a 2014 Wrangler if they need a make/model/year.
Go to Amazon and type in "front shock bushing" and you'll see lots of options that can easily be cut down.
Amazon.com : front shock busshing
I’ll try that
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
2004 New Holland TS115A (A64126)
2004 New Holland...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2017 Ford Box Truck (A62613)
2017 Ford Box...
