Bolt Size Help
/ Bolt Size Help #61
Hello, I am trying to find the correct size bolts to fit my M6060 I am attaching a picture I found showing the bolts holes I am looking for. I have tries several sizes both metric and SAE but to no avail. And I have looked at the diagrams at Messicks and they are not shown. Anybody Know what size these are metric standard fine thread pitch etc. I need bolts to fit up in the two holes in front of this bracket someone else built in the picture. Thanks
With a basic caliper, you can measure, then compare to a bolt ID chart or document. This is an excellent resource: https://www.boltdepot.com/fastener-information/printable-tools/Printable-Fastener-Tools.pdf or Fastener Size Tables | MechaniCalc. I had to replace some sheared bolts on my Mahindra 3616 front axle hub. It turns out they are a metric fine thread that I was able to identify by measuring the bolt diameter and number of threads per inch. Also consider bolt strength as shown here: Hex cap screw strength comparison | Fasteners, bolts, screws and more from Atlantic Fasteners. And finally consider tightening torque Bolt Depot - US Recommended Bolt Torque Table and Bolt Depot - Recommended Torque for Metric Bolts
/ Bolt Size Help #62
I usually resort to my tap & die set to find a bolt or hole size & pitch. Try different taps to see if you can get one that threads in. A tap works better than a bolt for this since it will clean paint and debris from the threads. Use care so you don't cross thread.
If all else fails, you can always drill & tap the holes for a larger bolt size.
I found a safer way is to use a "thread restore kit" that resembles a tap and die, but is not designed to "cut" threads, but to clean out and "roll" buggered up threads.
Saved my bacon bits a few times. Posting a link to Amazon for convenience only, not endorsing them or the vendor.
/ Bolt Size Help #63
You're thinking of JIC. Joint Industries Council 37° flare angle. And further investigation suggests that while JIS standards dictate for ferrous and non-ferrous materials, fastener threading standards are absent.
Nope.
I know what JIC is. I have dealt with hydraulics for a few decades now.
Someone earlier mentioned that it could be JIS threads in them holes. And the only time I have heard JIS and threads referenced together is when dealing with pipe/tubing fittings. Though have never used them in person. Quick google search seems to point to a BSPP thread but with a 30 degree seat. Dunno, but in my comment I definitely meant to say JIS
/ Bolt Size Help #64
I lost a Zerk (grease fitting) from my Kubota front end loader. Tried metric threads with no success. Ordered the Zerk from the Kubota dealer, and fit just fine. I'm guessing it was JIS threads. I'd never heard of that thread before and am glad I didn't try forcing metric. OP ought to just call Kubota dealer, send 'em a picture of where the bolts go for which he seeks, and order them.
/ Bolt Size Help #65
Our local TSC has a wide selection of nuts and that's how I found the correct size for a nut I have having a hard time finding. I used a thread pitch tool and ordered the nuts from Amazon. They didn't fit.. thought I was going crazy, went into TSC and found/bought the same nuts I had already ordered, M10 x 1.25. Turns out they shipped the wrong nuts (M10 x 1.5). Here's the tool: Grip Thread Pitch Gauge MM & SAE Markings - Hand Tool Sets - Amazon.com
/ Bolt Size Help #67
Can you pull out the bolt that screws into the same piece then check it with a Thread Gauge
/ Bolt Size Help #72
So I crawled under my M7060 this afternoon, and as I thought, they are 14x1.5. You definitely want to run a tap
or thread chaser in the holes. You might get a bolt in the holes without cleaning the paint and crap out of them first, or you might not. I work in a machine shop so I just borrowed taps when I was making brackets for those holes.
I can assure you guys that there are JIS hydraulic fittings. Like a JIC but with a 30 degree seat instead of 37 and I believe the threads are British Whitworth. They are all over the Okuma CNC machines I deal with.
/ Bolt Size Help #73
I see bolts next to the open holes. Pull one, see if it fits, then size it
That isn't his tractor. Just a picture on the internet.
He did explain all of this
/ Bolt Size Help #74
I like my Thexton 432 Universal Thread Gauge pack.
4 pieces,measures pitch and diameter.
Under $14
M14x1.50 is still my guess.
/ Bolt Size Help #75
Nope.
Ja, they do exist:
/ Bolt Size Help #76
So some confirmation of M14-1.5.
Interesting they upsized that hole from the MX/grand L.
Makes me wonder what the original use is for those holes? What option or accessory or use did Kubota have in mind when they machined those holes in that exact spot in the casting?
Ja, they do exist:
That's just a regular ole metric bolt.
/ Bolt Size Help #77
The two open holes have thick paint in them from the manufacturer. So no bolt will fit till you clean/remove the paint from the threads.
/ Bolt Size Help #78
....and use a bottoming tap to get threads as far to the bottom as you can.
/ Bolt Size Help #79
The M is a larger frame tractor than L's or MX's. This a utility tractor not a compact. What the designed usage of the holes are I can't tell you. I believe Neil Messick had a video of a boom or bank mower mid mount that might have utilized them in some way. It was on the highest HP version of the M.
I am very positive the holes are 14x1.5
/ Bolt Size Help #80
The holes and finished surface may have been used during the machining process for fixturing or for holding during assembly.
  • Good Post
Reactions: jmc
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Kuhn Knight Verti-Maxx 5032 Feed Wagon (A66408)
Kuhn Knight...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
