Quiet muffler
/ Quiet muffler #1
ibpdkelly
Moseley, VA
Kioti LK3054
Hi. I am tired of wearing ear protection on my Kioti tractor. Is their any good reason not to put a nice quiet automobile muffler on my tractor? thanks for opinions!
/ Quiet muffler #2
No! There is no good reason to not put a good muffler on. DO IT!
The counterman at the local auto store has pages and pages of options. I got one at O'rielly's
You just need the inlet pipe size, and a good idea about how the body should be configured to clear structure and outlet where you want the hot smelly gasses to go.
/ Quiet muffler #3
Is the muffler on your Kioti mounted to the engine? Diesel? If so... you may reconsider touching it.
I worked on a muffler problem back in '93 on the John Deere 430 garden tractor. The muffler had a high service part usage and it needed to be investigated. The mufflers were cracking through the mounting bracket(s) prematurely. It used a Yanmar diesel engine and a muffler which they provided. Yanmar had violated their own design guidelines by mounting the muffler directly to the engine. As it turns out, the high mass of a muffler coupled to an engine with strong firing pulses (like a diesel) creates a fatigue failure nightmare! Some tractors would run to high hours and others would fail within 100 hours... it all came down to the individual engine. Some run smoother than others.
Know that manufacturers do engine/muffler mounting regularly but not without much finite element analysis to pull it off.
/ Quiet muffler #4
Great post Dadohead - never knew that. Thanks for sharing
/ Quiet muffler #5
I find that my tractor is not annoyingly loud enough to bother me just running on its own. Implements like brush hogs, wood chippers make me wear ear defenders.
/ Quiet muffler #6
I have a 430 and have had to replace the muffler twice in the last 250 hours of use. The Yanmar is a good engine, but like you observed, they do vibrate/shake considerably at certain RPM settings. After the second muffler broke, I started watching the engine at different RPM settings and figured out why the mufflers were fatiguing and breaking. Now I know where the run the engine, other than wide open, and have over 100 hours on the current muffler with no signs of fatigue cracks in the muffler or mount.
I agree though, the location and mounting on 430s is a bad design.
I have a 10KW genset I scratch built with the same 3TNA72UJ engine as in a 430 uses, and I used a flex coupling between the engine and a frame mounted automotive muffler which works quite well.
/ Quiet muffler #7
Very nice. A Gem of a Generator. I think that flexible coupling might be the right piece to incorportate in a planned upright exhaust for our Kubota M59. It's been rather slowly coming together in my mind. Too slowly compared to most of my projects. I seem to be stuck.
The M59 is a 60hp turbo pre-tier IV & so without emissions complications, but is a sooty engine when changing RPM. In fact, soot and exhaust smell is the main reason to move the exhaust.
my preference would be to run the exhaust over to the right side and up to get it as far away from the operator as possible. Exhaust above the canopy. But moving it that far means more pipe, or using some sort of insulated pipe, & has me wondering just what the limit on pipe bends and length should be.
In fact, not having a feel for the pipe and muffler flow restriction and wondering if the turbo has some requirement there has been a holdup on this project.
Any advice would be appreciated.
rScotty
/ Quiet muffler #8
Oh man... sorry you've had trouble. It's like hearing one of your children is out terrorizing the countryside.... "what has he done now?"
It's been 30 years; I had just transferred to Horicon Works. I remember working with Yanmar engineers to get it solved (I thought). I ordered high temperature stain gages and rigged a 430 muffler. It was then mounted on a 430 unit from JD's "vault"; it showed acceptable levels when run. Then we borrowed a 430 from a mechanic in Experimental who said he had several muffler failures. The gage'd muffler lit up like a Christmas tree! The Yanmar guys said every engine is different. They made a change to the muffler and calmed it all down. If memory serves, the 430 was a framed tractor with the engine mounted on isolators. That made the design even more difficult as the engine/muffler is more free to move. Maybe your isolators are worn? Sounds like you have found a reasonable solution though.
Beautiful job on the gen set! Good call on frame mounting the muffler through a flex coupling! I know I wouldn't think of altering the engine mounted muffler on my 2520 even though it is a mono-block design.
/ Quiet muffler #9
I'm not familiar with the Kioti tractors or engines, but are you sure all the noise is from the exhaust? On some CUTs and SCUTs those naturally aspirated engines develop a lot of intake noise.
My JD430 is a prime example, the Yanmar engine has a short hose with a 90° bend into a metal can that houses the air filter which fits loosely into a plastic horn to pick up air from behind the grille. The drone from the intake is horrible and is probably at least as loud or louder than the exhaust.
Initially when I built the genset pictured above, I used the same air filter assembly as the 430, and the drone was really bad. Out of curiosity, I pulled the air filter assembly off my BX and installed it on the Yanmar engine, and the droning was was noticeably diminished. I even measured it with a sound meter, and I don't remember the readings, but I think it was over 10db less. So I bought another BX air filter assembly and also added a conical motorcycle type filter to to the inlet of that filter, which further reduced the intake drone.
Just a suggestion you might consider.
/ Quiet muffler #10
Some engines can't stand the back pressure. I accidentally bought an IH muffler for my Ford 3000 diesel. It wouldn't run worth a hoot. Removing and inspecting it I noticed you couldn't see all the way through it like my old Ford muffler. Went back and bought a muffler to fit a Ford and problem solved. So, since auto mufflers circulate gasses, you may or may not have a problem...otherwise a good idea.
/ Quiet muffler #11
As mentioned, intake noise can be considerable but is normally drawn with the cooling air because it is introduced to the tractor in the cleanest area possible. The cooling air sound is more offending yet. The safety standards (governing a tractor in the 430's class) dictate that they pass an operator ear test and sound power test while operating the most offending mower offered. The mower sound masks ALL of the other offending sounds and pretty much dictates the outcome. I don't know what class tractor your Kioti falls into or what you do (belly mower, rotary cutter?) that makes the sound so offensive but I would really think twice about cracking into it to 'improve' sound.
I would replace your ear protection with noise cancelling headphones. They don't clamp hard onto your head and are REALLY effective at reducing constant droning type noises like from your tractor/mower. You can run them without input or listen to music/talk from your phone via bluetooth. I think it will be a cheaper solution in the long run and save you way less headaches. Hope this helps!
KUBOTA BX23SLB-R-1 TRACTOR (A62130)
KUBOTA BX23SLB-R-1...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
2018 BOBCAT S470 SKID STEER (A62129)
2018 BOBCAT S470...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2014 John Deere Z930M Zero Turn (A63116)
2014 John Deere...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
