Trailer Tire Rotation?
/ Trailer Tire Rotation? #1
diesel85
Vernon, NY
Kubota BX2200
So I got 3 trailers: single, double, and a triple axle. They are all flatbed style haulers. Double and triple are equipment/car haulers.
They are all experiencing normal tire wear. Nothing out of the ordinary. I also keep an eagle eye to the tire pressures. Each trailer has differing amounts of mileage on those tires.
The trailers, when not in use, are stored in a climate controlled area.
In the past, I've rotated them every other year of use. Never seemed to make much of a difference, other than me doing some wrenching and inspecting of hardware and brakes.
Do others think I'm crazy, or should I keep on chugging along and keep to this schedule?
/ Trailer Tire Rotation? #2
The biggest benefit to rotating trailer tires is having the tire off to check everything else out. I have thought about rotating my trailer tires, on my dump trailer, but it’s more because the back axle has several plug/patches in each of them. The rears get beat twice as hard with all the gravel I drive, which supports rotating them.
/ Trailer Tire Rotation? #3
I do it every other year or so, usually the passenger side has more scrub wear (outer shoulder)
/ Trailer Tire Rotation? #4
I keep tabs on tire wear and inflation. I do pull them to repack the bearings every 2 or 3 years so I suppose I could rotate them easily enuf. I do not rotate them because I don't put enough mileage on them for it to be a concern. I replace the tires about the 5 year point. If they were on the road regularly, I'd rotate them.
/ Trailer Tire Rotation? #5
I agree, tandem axles, truck or trailer, will always wear the rears more.
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
New/Unused Landhonor Quick Attach Hydraulic Pallet Forks (A61166)
New/Unused...
2014 International WorkStar 7600 T/A 20ft Flatbed Truck (A61568)
2014 International...
UNUSED KUBOTA M1875 FRT BUMPER (A62130)
UNUSED KUBOTA...
2022 Kubota Z422-54 Zero Turn Mower (A63118)
2022 Kubota...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59909)
2020 ATLAS 2 POST...
