Garage Heater
/ Garage Heater #1
Dougryan
Webster, NY
Cub Cadet 3206
Hi. I have a 2 car garage that I would like to heat when I'm working out there in the winter. It is not insulated. I don't expect it to get into the 70's... just want it warm enough to work for a few hours without freezing fingers.
I've seen various types of heaters and I'm wondering which would be best.
I don't want a permanent unit connected to natural gas... but something portable with it's own fuel supply.
So, propane or kerosene?
Any particular make or model?
Thanks,
Doug
/ Garage Heater #2
The Val6 Daystar is one that I have used in the past. It puts out a LOT of heat. They are sold through local dealers and on Amazon.
edit: it looks like Amazon has stopped selling them but NAPA has them. I just realized that you are local, so check with Kepner Equipment in Canandaigua.
/ Garage Heater #3
I have a 2 burner that sits on top of a propane btl.. when it gets cold in SC..
No real need to have anything permanent down here..
I also put a fan BEHIND IT, on low, to blow the heat where I need it .. it works REALLY WELL..
I can get SEVERAL FULL 8 hr days on a “grill” bottle..
/ Garage Heater #4
The kerosene torpedo heaters work very well to heat up a 2 car garage. Although with the price and availability of kerosene going in opposite directions, this might not be the best way to go.
/ Garage Heater #5
Ditto for a small propane unit of any type.
/ Garage Heater #6
Figure how much BTU you'll need then add 50%. You'll need the extra if you're using any flame for heat. You'll need to leave a door or window open for fresh air. If you don't, you WILL die. :cry:
/ Garage Heater #7
Be careful of Carbon Monoxide with your heating source.
I installed a wall mount forced air propane furnace in my shop. Induction vented to outdoors through wall. I also put the thermostat on a manual timer and a thermostat cutout on the vehicle door. I use a large propane (30 gal?) cylinder for gas. The furnace cannot be left on inadvertently because of the timer when you leave and it will shut off any time someone opens the big door. Kids.... :)
/ Garage Heater #8
A lot of the newer propane heaters are equipped with oxygen depletion sensors that will turn he heaters off if the 02 levels drop to an unsafe level but yes, it is always best to add a little fresh air to the area.
/ Garage Heater #9
With no insulation in the ceiling, I would go with an infra-red propane heater.
/ Garage Heater #10
Personally I much prefer permanently mounted heat sources but short of that I’d get a propane torpedo heater. A diesel torpedo heater will throw way more heat but you don’t need that volume and the propane is cleaner.
/ Garage Heater #11
I have a wall mounted Enerco infrared heater that came with a thermostat and mounting bracket that has heated my two car garage for many years. It heats the mass not the air. I only turn it on when im working in the garage or on the tractor. Propane is way cleaner than kerosene and any heater needs to be at least 18" off the garage floor. ( NYS Fire Code)
/ Garage Heater #12
Cheapest garage heater -- don't stand too close
/ Garage Heater #13
Same situation here as the OP...a non-insulated 2 car garage that's also my shop (way too useful a building to "waste" parking a car in :D). I use a woodstove. It's one from my previous house that my wife thought too utilitarian looking for our current house. Mostly I burn stuff I wouldn't burn in the house...pine, spruce, punky stuff, etc. Burns hot, but not long but that's fine. Takes a couple hours to bring it up to 50° +/-, so if I have a project I'll start it up, putz around in the house for a couple hours then do what I set out to do. Got a couple 6" fans to circulate. Does the job, and there's no shortage of crappy wood around to burn in it.
/ Garage Heater #15
Big fan of quartz tube electric heaters. I have some twin 16 inch tube heaters I use in our 30' X 35' insulated garage with a 12 foot ceiling. Easy on the electric bill, I can mount them on a wall if needed, and the tubes haven't burned out in 15 years. Just gotta remember to blow dust out once and a while. Since they are infrared, they can be pointed to a specific work area.
/ Garage Heater
Great information
Hi. Thanks for the local recommendation. I'll check out the Val6.
/ Garage Heater
Hi all. Thank you for all of the recommendations and advice. I think my non insulated garage is leaky enough to invite fresh air without any extra effort. Good to look for a unit that has some kind of O2 safety shutoff.
I recall my parents having a kerosene heater for the house many years ago. And the smell... But it sounds like modern kerosene/diesel are much better about that.
I have one of those propane flame throwers already. Never even thought of the redneck option.
The Val6 or a propane torpedo seem like the best options for me. Time to go shopping.
Thanks,
Doug
/ Garage Heater #18
For some odd reason, I have a thing about not having open flames around fuels and solvents.
I like the little ceramic electric heaters because they are low temperature and less of a fire risk. However, they are only 1000-1500W. They are OK for your immediate area, but I'm not trying to service a tractor when it is -20F either.
All the best,
Peter
/ Garage Heater #19
I had this problem in the seventies when I had no money and absolutely needed my car fixed. I found that if I put my wrenches in a bowl of warm water to heat them up that I could work much more comfortably. Obviously this limited my selection of tools but I got it done.
/ Garage Heater #20
These days, I bet you could even use a heating pad, don't you think?
All the best, Peter
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2019 CHEVROLET SILVERADO 2500HD TRUCK (A62130)
2019 CHEVROLET...
2022 Big Tex Trailer Trailer, VIN # 16V3F4822N6178218 (A61165)
2022 Big Tex...
