Garage Heater
/ Garage Heater #41
Spanks, I use a waste oil heater at work but we generate about 2000-2500 gals of waste (mainly hyd) oil. The waste oil furnaces are nice but they are costly and use it up rather quickly.
If I was using temp at a home garage I’d consider bullet type propane or kero heaters. YOuTube has some decent vids on DIY waste oil burners, some clever people out there.
wdchyd
Thanks for your information. I see the same around here with huge garages that have a large supply of drain oil using high cost purchased waste oil furnaces. I will look at the YouTube videos. Looks like for my small use the kerosene heater will be the choice.
/ Garage Heater #42
I looked at waste oil heaters a few years ago and was shocked at the cost. Unless you build your own I think it has to be a commercial application to make sense. I only have 5 or 10 gallons of used oil a year. I get rid of most of it by mixing it with pine shavings and putting a little at a time in my shop wood stove. It's great for starting the fire since it eliminates the need to fool with kindling.
KennyG
I generate like you a small amount of waste oil (about 30 gallons per year). Sounds like for sure not enough to purchase a commercial supplied heater. I asked a friend that is a weekend crew chief for a small family sprint car racing team what they used to heat their shop with. His nephew owns a machine shop and they built their own waste oil heater. I will start giving him my 30 gallons a year. He said he would show me their heater when I make the first delivery. Thanks Spanky
/ Garage Heater #43
I use a small propane torpedo heater. I never spend much time out in my work shop in the winter. This heater puts out a lot of heat. It's just right.
/ Garage Heater #44
Hi. I have a 2 car garage that I would like to heat when I'm working out there in the winter. It is not insulated. I don't expect it to get into the 70's... just want it warm enough to work for a few hours without freezing fingers.
I've seen various types of heaters and I'm wondering which would be best.
I don't want a permanent unit connected to natural gas... but something portable with it's own fuel supply.
So, propane or kerosene?
Any particular make or model?
Thanks,
Doug
If you have room, a small wood stove is perfect for that. Built a fire 30 minutes before working there, then let it burn out when you’re done.
John Deere 4455 (A64119)
John Deere 4455...
Mini Excavator Rake Attachment (A61572)
Mini Excavator...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61572)
2023 John Deere...
