Trailer choice before I make a mistake
/ Trailer choice before I make a mistake #41
Gooseneck has placement for 20%-25% of the trailer load to be placed on the tow vehicle.
Bumper pulls typically are designed to have 10%-12% of the trailer load weight to be placed on the tow vehicle.
That gives a Gooseneck a nice advantage in payload, a 4500 lb bare and 14k goose that moves 22% to the truck rear axle can legally have more payload than a 4100 lb bumper pull that gets 12% of the load onto the truck rear axle.
The goose or fifth always wins that fight.
A goose/5th is also pushing that weight straight down directly or close to the rear axle. A pumper pull is pushing down many feet behind the rear axle. On my 35' 12,000lbs toy hauler properly loaded. I have 1,500lbs of tongue weight.
Actual Cat scale weights on the front axle of my F350:
Truck only 5,300
Truck + trailer 4,620
Truck + trailer + weight distribution hitch cranked all the way up 5,000
Bumper pull doesn't just make the rear squat, it actually lifts & unloads the front. A WDH can counteract some of that, but is a pain.
Interestingly I only use a WDH on the toy hauler. My 22' deckover & tractor/impliments come to 10-12k, about the same as the toy hauler. I have a weigh safe hitch & always balance the load for 1.1-1.6k lbs. The deckover with a standard hitch pulls as good or better than the toy haulervwith a WDH. Length of trailer & surface area to catch wind have a lot to do with things.
I really wish my toy hauler was a goose or 5th. But I feel no desire to change out my deckover from bumper pull. Granted the deckover only does short runs under 30-45 minutes & rarely at freeway speeds. Where the RV trailer is longer runs often at freeway speeds. I rarely take it over 65 even though Colorado speed limits are usually 75. It just tows to twitchy & nervously at speed.
/ Trailer choice before I make a mistake #42
That’s not an advantage, if the truck can handle that extra payload. Most F-250/2500 series trucks can’t, legally. Also, a 14k GVWR gooseneck and a 14k bumper pull, both built the same, sans connection method, do not have the same payload. The bumper pull will have more, since it weighs less than the gooseneck.
GVWR minus the weight of the trailer equals the payload capacity. Some trailer manufacturers rate goosenecks higher, to give the goosenecks an advantage, a lot don’t. I refuse to buy a trailer that has the GVWR as just the sum of the axle ratings. I want to be able to use the tongue weight, to give me a payload advantage.
Yup. And there is nothing on the door sticker referencing and "tow rating".
Just front GAWR, rear GAWR and the total GVWR.
No reference at all to anything regarding towing.
Don't exceed any individual axle rating of truck or trailer, don't exceed any tire rating, and don't exceed any hitch rating and you are legal.
Don't try and pull a 12k or 14k trailer with a 10k hitch....or a cheap parts store insert with a ball rated for 6k.
GM did start putting more information, in the door. I believe it now includes the GCWR and maybe one other thing, over the old way of just listing the axles and GVWR. It is a pretty new thing.
/ Trailer choice before I make a mistake #43
Found an example:
/ Trailer choice before I make a mistake #44
Technically its the trailers axle ratings....minus the empty weight....PLUS the hitch weight = payload.
Those trailers that are rated at 15k GVWR but only have a pair of 7k axles is why I said the trailers axle ratings and NOT the GVWR. Because those trailers are already accounting for a little tongue weight.
A 14k bumper pull that weighs 3k empty....loaded at capacity will have 10% tongue weight. So a 12.5k load, 3k trailer weight = 15.5k......but but 1500# on the hitch and you are still at 14k on the axles.
A 14k GN that weighs 4k. Put the same 12.5k load on....total 16.5k....but put 20% on the hitch which is ~3300# and now you only have 13.2k on the axles. So "technically" the GN would be legal to haul a little more. Because it is capable of putting MORE weight on the tow vehicle than the difference in the trailer weights.
/ Trailer choice before I make a mistake #45
Incorrect. Gross Vehicle Weight Rating has one meaning. It’s used the same way, across the industry. Technically (meaning using actual definitions), the payload capacity is the GVWR (whatever the manufacturer specs that as) minus the weight of the trailer is the payload. Many companies even include stickers, helping explain:
You can’t go over your GVWR and be within the ratings. You may be able to go over and still be within axle ratings, that’s a different discussion.
/ Trailer choice before I make a mistake #46
I knew this seemed familiar. You didn’t learn anything, last time. I doubt you will, this time. No reason to respond, being the loudest doesn’t make you right. Unless you have something, other than “I say so”, to refute the multiple links I posted. Which you won’t, because it only exists, in your mind.
Here is the link to the last time he told me how wrong he was by repeating his own incorrect information:
/ Trailer choice before I make a mistake #47
I can tell you this. My 7k gross utility that weighs 2k has a payload of 6k with 1k tongue weight. That's per the manufacture, Quality Trailers in Ohio.
Similar, my Grand Design 311BHS with 14K gross fifth wheel has a pair of 6k axles under it and accounts for 3k pin weight on the truck.
When your scaled, they don't weigh the axles and the coupler and add them. They weigh the axles.... period. If your gross is 7K than the trailer axles better not be over 7k. You can another 2k on the coupler, but that's not part of the trailer weight, that's going to the payload on the truck.
Argue it if you want, but you'll be wrong while thinking your right.
  • Good Post
Reactions: LD1
/ Trailer choice before I make a mistake #48
Im not wrong. And if you do care to go back and re-read the thread you linked while pounding your chest.....you will see NONE of my posts in that thread arguing with you or about GVW. You were arguing with someone else.
And for every link or source you can cite saying what you claim....I can cite an equally credible source saying what I claim is true. Case in point is rock crawlers post above.
Seems even the trailer manufactures are confused.
If you get stopped and scaled they are gonna make sure you ain't over axle ratings. This hitch load is not on trailer axles...rather the trucks.
If you have a 14k trailer....you can put 14k on the axles.....period. not my fault that some manufactures choose the incorrect CYA method of GVWR minus empty weight for payload
/ Trailer choice before I make a mistake #49
What they choose to look at is up to the investigating LEO. I have had trucks disconnect from the trailers and weighed the trailer, alone. I have seen other LEO’s do it, too. That may not be how you conduct vehicle inspections, but it is a way some do. Also, not all inspections are the same. In fact, the variables are different.
Every time a driver crosses a jurisdictional boundary, the application of law can be viewed differently. My posts are written towards a best practice to best limit liability and exposure.
Here is an example of how things can be different, all based on the same laws. A lot of it comes down to what the Judges believe/allow.
Reckless driving tends to be a catch-all, for anything safety-related, that isn’t already covered, but its own Statute. When I went to the Academy, speed could not be the only contributing factor, toward a reckless driving charge. Some LEO’s were under the impression anything over 100 MPH met the factors necessary. We had a case go to court where a Trooper had arrested a driver, for going over 100 MPH. No other issues, just “excessive” speed. The Judge dismissed the reckless driving charge. The Prosecutor’s office later sent out an opinion on reckless driving. The way our Judges viewed reckless driving was it had to be a combination of factors. Some examples given, if speed was over 100 MPH, were if there was an unwilling passenger or if they were minors (and not the children of the driver), if the vehicle passed unwilling motorists (other motorists were assumed to be unwilling participants, unless it appeared they were running with the reckless driver/speeder), or if the vehicle was not in a condition to run at those speeds. One way the vehicle could be shown to be unsafe, thus reckless driving could be applied, was if the speed rating of any tire was lower than the speed they were going. You won’t find the speed rating of a tire in any Statute I’m aware of, but it can be a factor considered, for other charges.
You tell me I’m wrong and give examples explaining your perspective. However, you can’t seem to show me how I’m wrong. I’m coming from a background relative to our discussion and how I’ve seen these principles applied. Please, show me something that is official or at least, third party professional, that supports your argument. I’m not unwilling to learn. I am unwilling to take your word that runs contrary to everything I have experienced and read.
ETA: I am not currently a LEO. I was from 2008-2020.
/ Trailer choice before I make a mistake #50
Some trailers do consider hitch weight when they’re rating them. Some trailers don’t. I used to have a trailer rated for 22,000 gross weight with 10k axels under it. My 14k tilt trailer is rated for 11,000 pounds and it weighs more than 3k. My pintle hook trailer that’s the heaviest duty of the 3 that I’m convinced is de rated has claimed 10k axels and it’s only rated to carry 14,500.
/ Trailer choice before I make a mistake #51
Citing Rock Crawler isn’t a source. Please, cite an industry leader or official government document, contrary to what I’ve posted. I’m excited to see them.
There are a lot of things that can be checked. What and how is going to be determined by the investigating LEO. This is more different, from LEO to LEO than from one jurisdiction to another. Everyone seems to find what they like to look for/enforce.
Incorrect or correct is irrelevant, in that regard. If they use a “CYA” method, that will be yours to answer, if it comes up. It is unlikely to be an issue unless there is a wreck and it’s a suspected contributing factor. This is a big problem with all of the ”de-rated” trailers. I’m talking manufacturer de-rated, not printing off your own VIN plate or just registering it as such (which isn’t de-rating, at all). Technically, that is their new limit and would be enforceable as such.
/ Trailer choice before I make a mistake #52
Wow, you pointed out the fact that I "liked" a post. Far cry from you acting like I argued with you in the other thread and wouldn't learn....
You aren't worth the time to spend googling and linking. You can do that, and if you have I am sure you have also found contradicting information.
I really wish manufactures didn't assign a gvwr on trailers at all. List let us know what the axles are.
You insist that some LEOs make you unhook and some don't. So it seems even law enforcement cannot agree on best method....or better yet....it ain't about what is safe or what isn't....it's about an easy money grab.
If every axle and every weight is within capacity.....yet an Leo makes you unhook and now trailer is over so you are busted......ponder this: if your truck is over gvwr....will the LEO let you unhook the trailer to shed the tongue weight and all of the sudden call it good?
Seems what you are saying is that amongst LEOs....they have no standardization other that whatever suits them best at the time. Either the hitch load is part of the trailer GVW or it is part of the truck GVW...but it CANNOT be both.
/ Trailer choice before I make a mistake #53
I have a trailer that was de-rated by the manufacturer from 15,900 plus pounds to 14,500. The sticker on the trailer states there are 2- 7,000 axles. The truck is rated at 11,400 pounds. The front axle of the truck is rated at 4,800 and the rear at 8,200. My GCWR is there for 11,400 +14,500 = 25,900 pounds. If you add the 4 axles together it is 27,000 and it does not mean a damn thing.
If the front axle of the truck is greater then 4,800 then you get a ticket.
If the rear axle of the truck is greater then 8,200 then you get a ticket.
If the front axle of the trailer is greater then 7,000 then you get a ticket.
If the rear axle of the trailer is greater then 7,000 then you get a ticket.
If the combined total of all four axles is greater then 25,900 you get a ticket.
It is that simple.
The empty weight of my truck and trailer is 15,500.
GCVW of 25,900 - 15500 = 10,400 pay load.
As long as the weight of on each axle is under the rating as stated on the vehicles label your are golden, as long as the weight rating of the tires added together is greater the axle rating. For example I run a dually and the 4 tires on the rear axle are rated at 2680 each giving a total of 10,720 pounds. Far greater then the axle rating of 8,200. The trailer tires are rated at 4080 each, so the combined rating of 8160 is greater then the 7,000 rating.
That is what the DOT will look at as far as weight. I had the same DOT cop pull me over 4 different times trying to bust me and never could. The weight was all he was worried about since I run under 26,000 pounds.
FYI if your truck is rated at 11,400 and the trailer is at 15,900 (GCVW of 26,001 or more) then you need a CDL unless you are a farmer and moving a farm related load. This does vary by state.
/ Trailer choice before I make a mistake #55
It is that simple.
As far as the axle laws are concerned. You can be legal, on axles, but still be over on other ratings. How those may be enforced is based on a myriad of factors. Also, being overweight doesn’t automatically mean a ticket (in my area, anyway). How they weigh you matters. Portable scales must be given an error factor. Fixed scales get no error factor and you can only be forced to drive to a fixed scale, if it is within a certain mileage distance, of where the LE contact occurs.
Tires and axles are the big ones most guys checking trucks will look at. In Kansas, it’s partly because those Statutes are the most simply written.
Again, it depends on the LEO. I know a guy in southeast Kansas that dips tanks. I’ve never even heard of him doing anything with weights or other “trucking” stuff. He just dips diesel tanks, looking for dye. Most of the inspector guys I know are overall lazy, about truck inspections, because they are not into trucks. They do them because the have to. They get their inspections in (CVSA-certified inspectors must have a certain amount of inspections, per quarter) on trucks they don’t expect to find a problem on. A passed inspection still counts and everyone can leave happy (as happy as a driver can, anyway).
Let’s hope we don’t get into that.…
/ Trailer choice before I make a mistake #56
I have a 2012 super duty 6.2 gas with 3.73 gears. I purchased this truck to move my tractor which is a new Holland work master 70 with FEL. It looks like all I can pull is 12,500 with my truck. I can’t find anything that says I can pull more with a gooseneck than bumper pull. A gooseneck is going run a good 1,000 lbs more than a bumper pull.
if I purchase a 20’ deck over bumper pull trailer most of my weight will be up on front of trailer when I load my tractor and bush hog up. The bush hog actually will hang off trailer by three feet. So tractor has to go on first.
If I purchase a gooseneck than I more than likely will exceed my towing capacity of truck. Most 20’ goosenecks are 4800 lbs. looks like I either need to get a bigger truck or smaller tractor. No way I can afford an aluminum gooseneck.
My tractor weighs 5050lbs, the fel weighs 1600 lbs and bushhog weighs 1556. That’s 8206lbs and leaves me roughly 4300 for a trailer. Hard to find a gooseneck 20’ at 4300lbs.
Am I missing something here.
Holy Jesus what a pi$$ing match. Buy a bumper pull 22 foot trailer..
/ Trailer choice before I make a mistake #57
I've been in the towing industry for over 18 years. Add air bags, make sure you have a good tranny cooler and check your frame for rust/degradation. As long as the trailer has brakes and everything else looks good, just take it slow and you'll be fine. Make sure to use 4 chains on your tractor with binders.
  • Good Post
Reactions: JWR
/ Trailer choice before I make a mistake #58
My only contribution is check the payload rating. You may be surprised. I bought a 1999 F250 SD 7.3 years ago. The payload specification is only 1800 pounds. It specifically says in the owners manual "Do not put a camper on this truck". I think the 7.3 is wasted on something with this low payload. However, to pull my 2 horse slant bumper pull and my 16' flatbed with 2 tons of hay, it works fine. Still love my truck, not a real ranch truck like a newer F350 or F450 dually.
/ Trailer choice before I make a mistake #59
Seriously. That was my suggestion too. Truck will handle it fine.
  • Good Post
Reactions: JWR
/ Trailer choice before I make a mistake #60
The answer is always "it depends." How often will you be towing? How far? Are you towing in mountains or a lot of hilly situations? Is your F-250 a 4WD ? All those matter.
But let me pass on my own experience and then comment on where I think you are with this:
My MF2660 is roughly 1000lb heavier than your NH workmaster 70. I have loaded tires. I would guess the loaders are very much the same weight or close enough. My bucket is a very heavy 4-in-1 which weighs 1000lbs. I use a 7 ft Bush Hog brand hog which weighs 1460 lbs. I towed this 80 some miles each way in some serious mountains in WV (missing only the bucket) using my 2000 F-250 V-10 and Pequea 1018 trailer. The trailer weighs a hair under 3000lbs. No problems whatsoever. I have also towed the MF2660 and loader & bucket (without the hog) 330 miles on interstates including some long steep pulls but using a heavier trailer (approx. 1000lb heavier than the Pequea.) No problems. Your 6.5L V8 has enough torque and HP (not much different than my V-10.) The truth is the 3.5L turbocharged V6 has a few more HP than my V-10 had and equal torque figures... which is strange but true.
I have also towed the MF2660 minus the bucket and minus the hog (for 25 miles each way just to get to/from a Laneshark dealer,) on the same Pequea 1018 trailer returning with the 600lb or so Laneshark on the FEL using an F-150 3.5L Ecoboost. I do NOT recommend towing this sort of load with the F-150 other than short distances at slow speeds -- mainly due to weight of the truck being 1500 lbs lighter than my old F-250 V-10. The weight of the towing vehicle matters a LOT in terms of stability, steering and stopping. A 4WD truck will have heavier springs in back and tolerate more tongue weight better than a 2WD.
To heck with the towing capacity ratings of these various trucks. Your F-250 is plenty strong to do your towing with everything your describe. Both my old 2000 F-250 stick and my 2015 F-150 automatic towed the loads mentioned easily/well power-wise. Power is NOT the issue. Weight of the truck is an issue (you have good and plenty.) The heavier the truck the more stable towing.
I don't think the tractor necessarily has to go on first. Best is to cut and try and see what fits best for you. I do not think you can beat the Pequea trailers for quality and strength at a reasonable price. Mine is a 1018 deck-over. Pequea sells a longer 20ft deck-over which I recommend highly. There are many good brands of course.
There is nothing wrong with you using a "bumper pull" (really receiver hitch pull) trailer but there is no question that a 5th wheel design trailer is FAR better in avoiding fishtailing and sway as well as distributing the load better amongst your truck's 4 wheels. If you plan to do a LOT of towing with this entire load (and can give up normal bed space in the truck) then go to the 5th wheel trailer and don't worry over the weight. Otherwise, just use a good solid deckover with about a 20ft deck on it.
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2022 John Deere 5055E (A60462)
2022 John Deere...
2018 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2018 HYUNDAI...
2014 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2014 REITNOUER...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
