Pole Barn Addition
/ Pole Barn Addition
Here are some pics of the crane we built. The winch was the key. You can raise and lower the truss with much more control than using a boom pole alone. We also built a truss carrying jig so we could safely pick up the trusses with multiple points of contact instead of 1 point of contact. We screwed the truss to the jig with 2 screws so it could not fall off while being moved.
Found a close up of the winch. Had lots of help on truss day. Me, my brother in law, father and father in law plus a deacon from church. He's is retired as the shop manager from the local John Deere dealer, so a great friend to know when you have tractor problems!
/ Pole Barn Addition #23
Excellent! I already have my DIY barn up but I didn’t build it myself. I wish I would have left a header exposed on the gable end like you did. I’ll need to take the metal down and cut down to find purchase.
what did you cut your metal with? I’m told cutoff wheels will destroy the finish and therefore cause the panels to rust where they are cut?
Diablo makes a 7 1/4" circular blade for cutting sheet metal. Supposedly keeps the metal cool so it does not damage the finish or allow rust so I used that for most panel cuts. Did a lot with tin snips too. Had to cut all my soffit pieces by 1/4" and the saw would not do it, so I got a lot of experience with the snips.
I tried to find a crew to build the barn. The website said it could be built for $7000 with one of their contracted crews, but no crews worked in CT. I got a couple quotes in the $20-$25K range to build the barn not including the cost of the kit. Really enjoyed doing it myself, and saved a good chunk of change but would not take on another building this size.
/ Pole Barn Addition #25
Mr. Boylerman, was the winch AC electric powered? (One photo looks like the operator has a power cord in hand with the controller?)
Also it looks like you used the top of the loader frame on the tractor to anchor the support chain. How did you actually anchor the chain to the loader frame?
Was the chain adjustable? (Appears raising the forks would change the angle of the boom if the chain was not adjustable.)
And I understand the logic for using the winch for fine movement of the trusses. Very nice!
Thanks very much for posting the photos...a picture really is worth 1000 words!
Very helpful...
Yes, it was an AC powered winch from Harbor Freight that a friend at church let me borrow. We mounted the winch to the top of the backplate for my forks. The 20' pole was also mounted to the back plate. We had power at the build site, so it worked well. My loader arm mount has a pre-drilled hole at the base of the loader arm that we used to hook the support chain to. We could raise and lower the loader arms without changing the angle of the pole, so the chain length never changed. We could not use the loader tilt forward and reverse as that would change the length of the chain. The truss carrying beams on the barn were 12' high, and the trusses were 8' tall so we needed 20' clearance to set the trusses. With the loaders 7' lift height, we could easily get the trusses 3-4 feet above the carrying beams to swing them into place. We also tied a rope to one corner of each truss as we moved it, and that allowed us to swing the truss diagonally as we moved it into the barn as the trusses are 32' long and the barn is 30' wide.
/ Pole Barn Addition #27
Thanks for the detail...very helpful.
Great ingenuity!
Put the metal roof on this morning. Needed more man power so I recruited 3 fellow firefighters, 3 family members and 1 from church. Roof panels were 28’ long so things went quickly. We had 4 people moving panels to the roof and 4 on the roof screwing panels in. My wife kept us supplied with donuts, coffee and the pizza, chips and soda for lunch.
I have black metal trim pieces to cover the end rafters on order which will arrive in a few days and also have to install 2x6 rub rails in between the posts and on the barn wall to finish off the shed.
/ Pole Barn Addition #29
That looks awesome, nice work. Are you putting on a Denver-style rake trim on the ends? That is my favorite, it runs over the top then comes down the side with a drip-edge bend at the bottom. Very easy to work with and accommodates many different types of installs.
/ Pole Barn Addition #30
Are you going to cover the exposed joists? leave them natural or paint them? I like covering them with Hardie, and extending the Hardie past the bottom of the joist to create a bit of a drip edge. Then paint the Hardie and install the trim over the painted Hardie. Once Hardie is painted, you never have to paint it again!!!
/ Pole Barn Addition #31
I am considering Hardie board for my house build. When you say that you never have to paint again, is that in general, or are you expressing this because the hardie is covered by the trim? It seems like anything that accepts paint will need to be re-painted at some point. But then again, I see claims of 30 year warranty on hardie colors.
/ Pole Barn Addition #32
It's a general, overall comment based on how well Hardie holds paint. If a decent quality paint is used, and there isn't anything else to cause problems, then Hardie rarely needs to be painted again. Biggest issues with Hardie is if it touches shingles on a roof, or remains in contact with a wet area over time. My personal favorite paint is Valspar Duramax from Lowes. It costs less then Sherwin Williams or Kelly Moore, but goes on easier with better coverage and holds up great!!!
/ Pole Barn Addition #33
My experience with Hardie is that it takes paint very well. If the paint is good quality, it will last a very long time. It's really down to the paint quality as to how long that is.
The exposed rafter on each side will be covered by 2 pieces of trim. A 7"x1.5" L shaped black metal trim will cover the bottom 2/3 of the exposed rafter and a 5x5 corner length of black trim will cover the top 1/3 and attach on the surface of the roof. That is how the pole barn kit did the gable ends, so we are doing the same so everything looks the same. I am using metal trim instead of paint as the metal has a 40 year paint warranty. I don't want to have to paint the barn in my lifetime! Trim gets expensive very quickly. I paid $1000 for the 900 sq feet of metal roof and $500 for the trim needed for the 2 sides and end.
I do like the Hardie type boards. I trimmed out my log home roof, windows and made 3 board shutters for all the windows with Mira-Tech which is similar to Hardie board. Mira-Tech has a nice cedar grain to it which looks great when painted. The paint looks like new even after 5 years.
The black metal roof trim came in on Friday and we installed it today. My crew was my wife, dad and younger sister. We got fascia trim and gable caps put on in a few hours.
Next is the wooden guard rails protecting the posts and bringing in some fill to raise and flatten the ground under the overhang so the firewood cages have a level place to sit. Then a few more yards of gravel. I have this week off of work so hope to finish everything this week.
/ Pole Barn Addition #36
You need to throw a big "Pole Barn Builders Thank You Barbecue" for all those volunteers!
Looking good!
/ Pole Barn Addition #37
BoylermanCT thanks for starting thread and others input here . Been kicking back learning and enjoying . On a side note I havent seen a Montana tractor in that great of shape in many years !!! ............ You all keep that tractor real pretty , looks like she sleeps " in the house " ! (y)
/ Pole Barn Addition #38
The trim really ties it all together!!!!
Looking good!
You said it! I do feed my workers every time we have a workday. Last week was pizza and this week was Jakes Wayback Burgers. And we are having a Pole Barn party this coming Sunday. I special ordered eighteen 16 ounce thick cut NY Strip Steaks that we will cook up for everyone! Should be a great time for all.
My Montana has been a great tractor. It is a 2008 that I bought in 2013 with 175 hours on it. It now has 475 hours. The only thing I have had to do it replace a hose or two. I am taking this week off to organize the barn, and will be washing the tractor before parking it in its new home. I am hoping it will serve me well for many more years to come.
2022 EZ-GO ELITE...
JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A64553)
JMR 78in Dual...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A64194)
1995 Khronert 307...
