Tires do not spin
/ Tires do not spin #1
Randolph
Kioti Ck3510
Got a ck3510 hst shouldn't this thing spin the tires when you go onto a pile of dirt or gravel
/ Tires do not spin
It just bog's down and doesn't spin
/ Tires do not spin #5
OK, that is a little better description.
I wish mine had more traction than power. I've added weight and still spin tires when i want it to dig in.
Don't know your situation, though.
/ Tires do not spin #7
What tires? Is the parking brake off?
/ Tires do not spin
Took the fel off. And backhoe off . Chain to a tree. It will not spin.
/ Tires do not spin #11
Depends entirely on the traction and range you are in. Mine will spin as I have sand for dirt. The more weight you have, the lower your tire pressure (to an extent), the better your traction will be.
Being in the proper range, having the proper throttle, and working the HST pedal properly (don't just bury it) are all essential for getting the most out of the tractor's traction and power capabilities.
As an example of incorrect range, throttle and pedal:
/ Tires do not spin #12
What RPM are you running at when you are doing this?
/ Tires do not spin
Tried all different rpms
/ Tires do not spin #15
On dry asphalt, I cannot spin my tires in low range nor stall it. The HST goes into relief. On dirt, 2 wheel drive, no counterweight/implement, it'll bury itself. In between these two scenarios are all kinds of variables.
/ Tires do not spin #16
Are your tires "loaded" with liquid or tire foam?
Do you have iron wheel weights attached to your wheels?
/ Tires do not spin #17
If the surface is gravel, dirt or grass, in other words a loose surface, and you have a reasonable amount of ballast, even if the tires are loaded, it should spin the tires. Even with the AG tires. It is sounding like the hydrostats relief valve is set too low. But we would like to hear more about your ballast, your tire loading/wheelweights and more about the surface of the ground.
/ Tires do not spin
Rear tires are liquid filled. No weights. Loose dirt . 2wd. Or 4wd. No squealing from hst relief valve. It will not spin at all. Rpm from idle to wide open. It's the same no matter what I do.
/ Tires do not spin #19
Are you using low range? Usually a HST will break traction in low. One of my family members has a Kioti CK25 that’s way underpowered for its weight and it won’t break traction in low. I would expect a 3510 would be able to. Your tractor is the same weight as the CK25 and has 10 more hp or 50 percent more. I suspect either you’re not using low range or using the transmission incorrectly. It’s not an accelerator pedal like a vehicle.
/ Tires do not spin #20
Can you hear the relief valve open, different flow sound, the pitch of the hydraulic pump change?
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
KMC Hi-Residue Plow (A64127)
KMC Hi-Residue...
2022 EZ-GO ELITE...
Case TV450B (A64126)
Bobcat T650 (A64126)
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
