bmaverick
Super Member
- Joined
- Sep 17, 2013
- Messages
- 6,967
- Location
- Beloit-WI
- Tractor
- Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
Did a look up on the AL-1235. 12V 35ARecalling back and checking into my Chrg. light problem there was several ways to setup these Yanmars. The Org. YM series,Rice patty tractors was hard on the Elec. Sys.. When digging in deep of my dash and Fuse panel I found out this to be true. Both VR. Old Mech. style still up in the Dash and the New SS attached around the Stering column. Found the bad connecton and then curiousity had me check the old one. Works fine!! So now I have both and then seeing my Alt. is actually 12V 35Amp. Which is Huge for my needs. No wonder My old battery lasted so long. Only 550cca. New 700cca now. Cold start is Minimal for the oil light to come on. I was actually shocked looking at the parts book. My Alt. is AL-1235 35Amp. and seen the next common Alt. is a AL-1215. It was much smaller at only 15Amp. and on the 2020 that was just mentioned is listed for it. That much smaller seemed odd.
A Yanmar Marine distributor has these too.
Alternator for Yanmar Marine
Used on 1GM, 1GM10, 2GM, 2GMF, 2QM15, 2QM20Y, 3GM, 3GMF,
12 Volt 35 AMP, without 2 pin regulator connector. (RM0060 with Connector)
Replaces Yanmar: 128170-77200, 128170-77201, 128170-77202
Replaces Hitachi: LR135-74, LR135-74B
RM0084
Some of these were also Denso back in the day. Long before American car companies dual sourced parts, Japan had done that decades earlier.
Iseki Tractor 3AF1BL,TE3210,TI1900,TL2100,TL2300,TL2500,TL2700,TU1700, TU1900,TU2100 12V/35A
Replacing:
Hitachi LR135-95B LR135-95 LR135-91 LR135-86F LR135-86C LR135-86B LR135-86 LR135-74B LR135-74
Iseki 6581-200-349 6581-200-338
Isuzu 8944237560 8941717780 5812003411 5812003381 5812003380 5812003281 5001810100
Massey Ferguson 3282883M91
Mazda H612-18-300 GE01-18-300A GE01-18-300 F851-18-300 D501-18-300 D401-18-300A D401-18-300 4828-18-300
Mitsubishi A1T33277 A1T31699 A1T31685 A1T31377 A1T31374 A1T25097 A1T25087 A1T25083 A1T25077 A1T23377
Nissan 34468-28200 34468-18200 23100-91109
Yanmar 128270-77201 128270-77200 128171-77200 124080-77201 121400-77201
Servicing: Mazda
B+ M5, Grooves 1, Pulley P, Fan EF A: 41.85 B: 13.50 C: 81.65 mm
MUSTANGSKID STEER LOADERS
920 96-89 Yanmar 3TN72 Dsl Hitachi System HI 35 12 LR135-91 AHI0097
930 89-88 Yanmar 3TN82E Dsl Hitachi System HI 35 12 LR135-91 AHI0097
930A 96-89 Yanmar 3TN82E Dsl Hitachi System HI 35 12 LR135-91 AHI0097
940 96-88 Yanmar 4TN82E Dsl Hitachi System HI 35 12 LR135-91 AHI0097
YANMAR
ENGINES
1GM 84-82 All Hitachi System HI 35 12 LR135-105 AHI0060
2GM 84-82 All Hitachi System HI 35 12 LR135-105 AHI0060
2T72HL 92-84 All Hitachi System HI 35 12 LR135-91 AHI0097
3GM 84-82 All Hitachi System HI 35 12 LR135-105 AHI0060
3HM 84-82 All Hitachi System HI 35 12 LR135-105 AHI0060
