Wood splitters
/ Wood splitters #11
I do split and sell wood in the side, part of why I wouldnt use the tractors hydraulics as the cycle time is definitely quicker.
The tractor splitter is cheaper and more theft resistant but I’d rather have the self powered splitter. I like to have help run the splitter while I’m cutting wood and I need the tractor to move logs. Maybe if I was strictly working by myself I wouldn’t care as much.
/ Wood splitters
What are you running for a splitter?
/ Wood splitters #13
Here’s what I have. The design is great. I’d buy the same thing again in a heartbeat. The actual tool is a complete POS though. Do yourself a favor and don’t buy anything from Ruggedmade.
/ Wood splitters #14
In my situation, buying a high end splitter ended up being a poor option. It made more sense to rent a processor. $450 for a two day rental every two years and I can split over 12 cords. I burn 6 cords a year. So cost is $250/ year.
I use a grapple to handle logs. I do not need to cut logs into rounds, or lift rounds onto the splitter. Easy and almost no labor to cut and split. No need for a “good” chainsaw, and no chains to sharpen/replace. The hardest part is stacking splits.
I am 71. It is unlikely I could process wood the normal way too much longer, so a mechanized option was my best option.
/ Wood splitters #16
Here’s what I have. The design is great. I’d buy the same thing again in a heartbeat. The actual tool is a complete POS though. Do yourself a favor and don’t buy anything from Ruggedmade. View attachment 715597
I am confused. You said you would buy again then said it was a pos? I am about to buy a splitter and ruggedmade was on my short list. Please explain why it is a bad splitter. Nearly all the reviews I have seen are postive. (for what that is worth!)
/ Wood splitters #17
I would buy the design as in a horizontal only 4 way with a lift again. I wouldn’t buy anything made by ruggedmade again. I’ve broke everything there is to break on the splitter. And I paid $2700 a few years ago. The same model is $4400 now. At that price do yourself a big favor and buy a TW or Eastonmade.
/ Wood splitters #18
Ok, thanks for clarifying.
/ Wood splitters #19
Personally I prefer stand alone splitter as it leaves tractor free to move split wood and unsplit rounds (by helper?).... As you get older you will find speed is not a necessity.... It all about users endurance....
/ Wood splitters #20
What are you guys using for splitters with faster cycle times?
I have one that I made on a I beam. K car axle. It has a 13HP engine and a 2 stage pump. Cycle time is 4 seconds
It is 2 slow with the tractor hydraulics. You want your splitter to be a stand alone unit. It will use less gas and the tractor can be used for other operations while you are splitting
2004 Ford Explorer SUV (A61569)
2004 Ford Explorer...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
