K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,922
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
Wonder why he edited out the test for the max load?
Which one? He went all the way past what the loader was rated for..?Wonder why he edited out the test for the max load?
I have a kioti lb1914 and the bucket on it is 54" wide and 20-14" deep. It is rated as a 19 hp tractor and I have noticed that compared to other compacts and their loader this one is much larger. I routinely max out the volume with sand and gravel or dirt/mulch and have been VERY impressed with the load capacity....as long as I have the rpms up where they should be.I'm looking hard at the Kioti CK3510SE Cab and started to look at the Deere 3035, 3038, etc and their lift capacities are much lower.
Is Kioti fudging their specs or is really that much stronger?
Make sure you are comparing apples to apples as far as tractor weight first. If they are the same weight, then physics dictates the weight a FEL can lift safely in most circumstances. Even though a mfg might say 2500 lbs, if you have a 3000lb tractor it isn't happening safely.3510 says 1600lbs~ and the Deere is 800-1100 depending on comprable models. Keep in mind I am not too familiar with Deere.
Great example of safe lift capacity. Truck bed is usually 4 ft off the ground. Look at the FEL capacity curves in the manuals and see where things are from 5 feet down (you need some clearance to get off the bed). Then you need to be able to to safely ballast the load.Good to know. I would be moving 1,000 pounds of pellets from time to time, but from back of truck bed to the ground.
