My Industrial Cabin Build
/ My Industrial Cabin Build #2,601
I looked into on demand electric water heaters. Higher amounts of energy needed and you require 30 amp and larger circuits for them.
I make myself crazy with all of this. I think space limitations are going to force my hand and make me use the tankless propane. If I had experience I would know that I needed a larger mechanical room. Probably twice the size.
You have "attic" space on both sides of the house with adequate room for a water heater. Just getting them up and down those stairs could be interesting.
/ My Industrial Cabin Build #2,602
What is going in your mechanical room that is making it feel too small?
/ My Industrial Cabin Build #2,603
I have run into another issue that is much more troublesome. My mechanical room is too small. It is 8’9”by 5’6”. I am thinking of moving the electrical panel to an alcove near the back door this would put the panel on the outer wall, making it easier to pull the electric in. That would free up the space i. The mechanical room that I need.
Be careful where you put that elec panel... code requires ample room to either side and I believe 36" clearance in the front. NOTHING can impede access to it. Oh, and no water lines near it as well.
On the full 8 foot wall, I have my radiant heat manifolds and will use most of that wall for the radiant heat plumbing and mechanicals. The wall to the right of that (if you were standing in the doorway, looking in), will have an on demand heat pump on the wall. I cant figure any other way to do it. I also need to have a water softening system and a well tank. That is a lot of real estate. On the other side is the electric panel, unless I can figure out somewhere to move it. The alcove wont work. You need 30 inches to place it in and 36 in front of it. The 36 was fine but the it is only 24 inches wide.
On your bump out that you added for your vent line being off a little. I would either do the entire wall that thickness, or cut the concrete and move the vent line.
Jefanna loves the bump out. It stays. But I have to say,it reminds me of my childhood. I have a lot of relatives in Luzerne county PA. And there is a little road where my Grandparents lived when I was a little kid. Across the street were several houses going to the right and left, and our family lived in every one of them. They had all been built by family members. Some were better built than others and they all had some “features”.
/ My Industrial Cabin Build #2,606
Can you add an a small room on to the house directly outside of your mechanical room? Put in an exterior door and use that room for all of your plumbing, radiant heat, etc; no one says it has to be "in the house".
Holy cow. That would add some complexity to my life. If I can’t figure it all out, I will put a small sediment filter in place, get the room going and move in, then revisit it. For wlectric I am going with the original locatiin and just moving forward.
/ My Industrial Cabin Build #2,608
Have you tested for hardness/minerals that you know you need a softener? With a large 1" sediment cartridge filter and water softener you could "stack" the water tank above the filters/softener in the corner of the room taking up a 2x2x8'H space.
The well bladder tanks are light (empty) but the softener canisters are heavy. You could add a large sand filter if needed later next to the softener.
Do you have a drain in the utility room? As I recall there is a Bathroom next to this utility room?
A quick sketch of the mechanical room. And yes there is a drain built into the floor.
We put up some siding this weekend, and I painted it today.
Why would I put up siding at this point? Well the far side of the house had no siding on it. And to get the electric run to the house, I need a disconnect on the outside. And it seemed logical to me that I might want to put up the siding first and then attach the disconnect box. Unfortunately we only got half a wall done. We had some farm business to take care of that ate up a bunch of time this weekend.
I have also been working a deal to get a second tractor up here to help me deal with some of the things that have been giving me a lot of challenge and don’t exactly fit into the realm of my Kioti. Looking forward to that, even though we have very little time to spare for farm work.
I just need to chew harder.
/ My Industrial Cabin Build #2,611
A second tractor? Do tell!
Well, it’s made in America.
Jefanna has been asking me to teach her to use the rotary cutter. When things are overgrown, it makes her very anxious. She gets overwhelmed by the visual and starts to doubt that we can ever make this place a decent home.
I walked into a local power equipment place looking for the Stihl chainsaw sharpener you guys mentioned. I walked in, saw Echo saws, did an about face and headed back to the truck. As I was climbing in the truck I saw a used compact tractor with a cutting deck.
My 7th wedding anniversary is coming up. And being the romantic guy I am, I I started working on a deal to give my wife something she can mow the front field with. There is no way that I’m turning her loose in the Kioti, with a 7 foot rotary cutter on the kind of terrain we have. She uses the Kioti and is really good in it but some of the stuff I have cut with that thing is just too sketchy. And sometimes, she gets flustered and I just don’t want that situation. Something smaller, closer to the ground and better visibility seemed like the correct tool.
/ My Industrial Cabin Build #2,613
I like your mowing plan - is it an OE belly mower under the CUT? Definitely much easier to use. But dude, now you need to start on the barn, can't have everything sitting outside forever.... 🤪
Glad you have a floor drain in your mechanical room. Our architect forgot to put one on our plumbing plan, and the seasoned, grizzly old master plumber we subbed decided it wasn't his responsibility to consider it either. So my water heater has to sit in a pan, taking up more room. F^&(**ng stupid.
/ My Industrial Cabin Build #2,614
No drain and no pan on my WH.
Hope tractor works out.
/ My Industrial Cabin Build #2,615
Waiting patiently for pictures of Jefanna on her new toy! Opps, I ment tractor! Jon
/ My Industrial Cabin Build #2,616
What's wrong with Echo saws? For me it's the easiest saw to start .
/ My Industrial Cabin Build #2,617
- Suggest if you do a Combi Heat/DHW wall mount unit - Rinnai make a good unit that is modulating and this means only one Propane connection, vent etc and saves space. Also you have 3 heat sources - Wood, Mini Splits, and the Boiler, so likely the radiant is for BR's and comfort.
- Have you had the water tested for hardness and minerals? Also how does it taste? If its decent then defer the softener until later. Also, we had hard water in PA but did not like the "softened water taste" so ran the sink and drinking kitchen sink supply line non softened.
- Drain's - the softener needs a drain connection and the water tank, and boiler need a drain nearby - the softener recycles every week or so depending on the hardness. You could route the softener drain to the toilet vent stack behind the room as an option.
  • Mech Room .pdf
/ My Industrial Cabin Build #2,618
If you do end up with an on-demand water heater be advised that even moderately hard water will destroy them in short order. Ask me how I know... A softener is critical from day 1. Don't put it off.
I was looking for a Stihl sharpener. So I figured if they sold echo, they wouldn’t have the sharpener.
I own a husky, a Stihl , two Dolmar and a Makita (rebranded Dolmar). I run saws that run well, have the proper inertia brake and provide good value for my dollar. Brand is a factor but isn’t the only factor.
/ My Industrial Cabin Build #2,620
Are you looking for that Stihl 2-in-1 sharpener that takes down the rakers and sharpens the cutters in one shot? That is made by Pferd and several companies re-brand it. Amazon has the Stihl ones and Pferd ones.
Pferd: https://amzn.to/3oocogi
Stihl: https://amzn.to/3a0qjAp
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNUSED FUTURE QSJ HYD MINI SWEEPER (A60432)
UNUSED FUTURE QSJ...
PONDEROSA PINE TONGUE & GROOVE (A60432)
PONDEROSA PINE...
2018 GENIE GTH1056 TELESCOPIC FORKLIFT (A60429)
2018 GENIE GTH1056...
(INOP) JOHN DEERE 240 SKID STEER (A60430)
(INOP) JOHN DEERE...
(6) 18X8.50-8 GOLF CART TIRES (A60430)
(6) 18X8.50-8 GOLF...
