Hydraulic problem
/ Hydraulic problem #1
J&R
2005 farmtrac 535
3point hitch comes up a few inches and stops then a few more inches and stops front End bucket doesn’t work at all. Filter has been changed and screen checked. Does anyone have any ideas. Is it the pump? any help would be appreciated.
/ Hydraulic problem #2
It COULD be the pump but it's unlikely. Check your hydraulic fluid level, it may be low. Also check for any loose or leaky connections. If you have quick disconnects on your hydraulic lines sometimes problems are solved by simply taking them apart and reconnecting them.
/ Hydraulic problem #3
JR
What make and model of tractor is this?
What were you doing prior to things stopped working?
Any new or unusual noises?
like roadworthy states check fluid level, for leaks, etc.
/ Hydraulic problem #4
Does the tractor have hydraulic remotes?
/ Hydraulic problem #5
Add more details, such as behavior and background. Pumps alone do not operate intermittently.
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2015 C&M TRAILER 14 ENCLOSED CARGO TRAILER (A60736)
2015 C&M TRAILER...
20' CONNEX BOX (A60736)
20' CONNEX BOX...
2013 Ram 3500 Utility Flatbed Truck (A60352)
2013 Ram 3500...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
