Comparison Seating
/ Seating #1
Torvy
Super Member
North East Texas
TYM T574H
So my wife has made it very clear that she expects to drive the tractor and not just once. Not a problem except she has never, so training will be very important. But for now, I need to figure out how difficult it is going to be to find a CUT that will fit both of us. Ultimately, I will need to test drive them, but the current list is over 40 different makes/models. I am 6'1" 230, she is 5'6" and probably the same, I don't know for sure.
My goal with this thread is to learn what tractors have good (or bad) seating. So far, the manufacturers' websites are woeful in that regard. Adjustable is the most they seem to say, if that. Thanks TBN experts! P.S I think this will help others, too.
/ Seating #2
5’6 isn’t that short. I don’t see you having any problem finding something you can both fit.
/ Seating #3
When I was tractor shopping a few years ago New Holland had cab models that had "buddy" seats in them, so someone could accompany a trainee...or give the grandkids a ride.
/ Seating
No grandkids. I am not even interested in having them. Kids wore me out. Also, not likely to get a cab. We are both too frugal for that.
How adjustable are the seats? Who has comfortable open stations?
/ Seating #5
Look for models that have a suspension seat. They usually have far more adjustability than a standard seat. I added one to my tractor and man what a difference!
/ Seating #6
I'm 5 ft 7" and on my Branson, I had to pull the seat all the way forward, just leaving one or two notches on the rack left, to get comfortable on the tractor. These Branson tractors do come setup for big/tall guys, providing lots of room and lots of travel on the seat rails towards the back.
Shortly after I got the tractor, I noticed a 2" spacer under the seat from factory, so I took it off and fabricated two simple flat bars with a couple holes drilled and this allowed me to drop the seat down 2" and therefore gave me a little bit more travel forward on the rails. This way my sister and mother that are a bit shorter can also drive the tractor easily.
The seat on this tractor is great! Really nice and comfortable as well fully adjustable.
/ Seating #7
If you need a comfortable OEM seat DON'T buy a Kubota unless you are both 5'6" and 99 lbs wet.
/ Seating #8
I am 6'1" 230, she is 5'6".
Many people over sixty-five years of age find climbing into a tractor operating station challenging, especially during a hot day. More find it challenging by age seventy years. Mounting TPH implements, especially PTO-powered implements, is a challenge for every tractor neophyte. Fueling a compact tractor from 5-gallon containers is physically challenging. Those with less than average core strength, bad knees or a bad back have to consider if operating a bouncing, suspension less tractor is a reasonable proposition.
I am familiar with Kubota compacts and to a lesser extent, Deere compact tractors.
No compact tractor I have operated has other than fore-and-aft seat adjustment. Due to dust accumulation you have to regularly clean and lubricate the seat rails with some form of dry lubricant or the seat movement changes to seat stationary.
No back tilt. No variable lumbar support.
DeLuxe tractors have tilt steering wheels, economy tractors do not. Kubota Grand L tractors have Grammer (brand) air ride seats.
Within Kubota's line up I find the operating stations to be a bit cramped through 2,800 pounds bare tractor weight (L2501/3301/3901) aggravated by a hump beneath your feet and an immobile steering wheel shaft.
At 3,700 pounds (MX, Grand L) the operating stations are more spacious and the floors nearly flat. MX has an immobile steering wheel shaft. Grand Ls have wheel tilt.
I may be corrected, but I expect there is no information to report, beyond fore-and-aft adjustment.
Operating a tractor you are sitting high, looking around in all directions and bouncing most of the time. It is not like operating a car, low to the ground, on smooth pavement.
/ Seating #9
My Kioti CK has a well padded, adjustable air ride seat. I'm 6'3" long inseam, my wife is 5'4" short inseam. We can both adjust the seat to operate the tractor comfortably.
Patrick
/ Seating #10
The economy kubota seats aren’t great but the better ones are fine. I see you have a M59 which has the better one. What do you dislike about that seat?
/ Seating #11
The slippery seat is sloped forward and has 3/4" suspension travel. If I'm not wearing a seatbelt every bump means I bottom out on the suspension, crunch my spine, then slide off the front.
I have a cab now so one day I'll splurge on a Grammar cloth seat with an air ride suspension.
/ Seating #12
You won't have an issue with the height difference. I've been teaching my son (10) and daughter (14) how to drive the tractor and they can reach the pedals just fine. My son isn't even 5' yet and my daughter is only 5'2". My seat does move forward though and my son has to reach a bit for the clutch pedal due to the throw, but the brakes and go pedals are easy for him.
/ Seating #13
Comfort is a relative thing. I'm 5' 10" and 220. My seat is adjusted to NOT bottom out on the most severe bumps on my property. The longest time I spend in the seat - around 4 hours. And that is rare. Normally - I'm up and out of my seat about every 20 to 30 minuets. This will make a difference.
My M6040 is open station with a canopy. I find my OEM Kubota seat to be perfectly fine - for me.
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
