LED Lights on ROPS
/ LED Lights on ROPS #1
wdchyd
Elite Member
Hooksett, NH
Kubota B2320
I figure the TBN Braintrust has lots of good advice, links and pics. Looking for any ideas on mounted LED lights on my ROPS bar for my Kubota B2320 TLB. I’m tired of the dark kicking out of my seat when things to do (digging, plowing etc). Preferably I need better lights forward and back, or at min able to flip over.
Let’s see what you have.
Thanx in advance,
WillyC
/ LED Lights on ROPS #2
I noticed them as options on UTV ROPs. Single and double bars. One also had some grill mounted ones. As long as you don't cut into your ROPS and hurt the structural integrity, you should have options. Someone smarter than me will need to tell you about wiring them...is there already a harness in place?
/ LED Lights on ROPS #3
/ LED Lights on ROPS #4
Not sure, if not I’ll make something up with a piece of SO cord, fuse holder, hopefully a dash switch.
I see TSC has a few LED choices I’ll check the local store
/ LED Lights on ROPS #6
I was just going to ask a similar question. I have read through the thread that i7win7 started, and have a good idea on how I want to wire a panel and lights.
But how does the ROPS mounted bars work for general lighting for those that have them? I would think they act like a lantern, throwing light in every direction including right back into your eyes.
/ LED Lights on ROPS #7
My rops is behind me, lights above head, no problem with lights shining in eyes. Bugs - well they're attracted to light. you may want a bee keeper's hat. Don't know if my cooling fans are strong enough to keep the bugs away
/ LED Lights on ROPS #8
Here’s how I mounted mine
Only lights on in this picture are the ones provided by the tractor
/ LED Lights on ROPS #9
Thank 96!
I guess what I was thinking is that I didn't want my head bathed in light, but the work area around me. 96's pictures show that the operators station stays pretty dark still.
/ LED Lights on ROPS #10
I have it pointing just ever so slightly down. The lights never bothered me. Basically starts getting bright at the beginning of the hood.
/ LED Lights on ROPS #11
Amazon's cheaper.
/ LED Lights on ROPS #12
Here's how I did mine since I have a canopy. I spaced the width in the front the same as the back so If I later determine I need more light forward I can get the same light bar and install instead.
The lights and harness is all from TSC. I get them when on sale and/or I have a coupon for XX dollars off.
/ LED Lights on ROPS #13
View attachment 714490View attachment 714491View attachment 714492View attachment 714493View attachment 714494
Love that the Wasp & Hornet is essential as the fire extinguisher (y)
/ LED Lights on ROPS #14
I bought some small led's for all 4 sides of my golf cart (old, cheep, 10 acre; now I can't live without it :=)
Haven't found that "tuit" yet, but they feel pretty sturdy - connections can either be soldered or use standard spade lugs. Each switch is NO/NC, so you can do stuff like use one switch to SWAP which light is on if you want...
Also bought one of these
If I get many more "projects" ordered, might need another shipping container for storage :rolleyes:... Steve
/ LED Lights on ROPS #17
Mounting inside the ROPS with a magnet lets me reorient the light easily and partially protects it from tree branches. I tried three different neodymium magnets, one with about 90 lbs of pull ($2.70@), one with 112 lbs pull ($3.67@) and one with 405 lbs of pull ($26.35@). All 3 worked fine, the 112 lb/pull was best. The one with 405 lbs pull was overkill for my use.
/edit - prices from 2018.
/ LED Lights on ROPS #18
Magnet vs tree branch -- tree wins every time. Consider what types of operating environments you will be in.
2 magnets. One magnetic base and another inside ROPS with chain connecting? If light pulls off the other will catch it. But now we're starting to overthink this..
/ LED Lights on ROPS #20
Good suggestions, especially 'inside' the ROPS. My 4105 has an existing 'bullet' type power connection, behind my seat, that is energised using my standard lighting switch (OFF/HAZARDS/HASZARDS-LIGHTS/LIGHTS).
My only suggestion is to include an anti-vibration layer when attaching to the ROPS. A cut-up "Koozie" (foam neoprene) between the bracket/ROPS provides that.
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
Sudenga 10 x 63 Swing Away Auger (A66408)
Sudenga 10 x 63...
76in. Low Side Skeleton Skid Steer Bucket (A65640)
76in. Low Side...
Plasma Cutter (A66408)
2002 Freightliner FS65 School Bus, VIN # 4UZAAXAK02CK16471 (A65563)
2002 Freightliner...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
